Home » Newcomers » Newcomers » new install for a new user of os x 10.4
new install for a new user of os x 10.4 [message #155465] Mon, 05 June 2006 00:42 Go to next message
Originally posted by: rafael.saucedo.ws
I havae just installed eclipse on os x 10.4. When i try to run the app I
receive an error which tells me to look in the .log file. The following
is what i found in the file.
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Does this help? Can anyone help?
Re: new install for a new user of os x 10.4 [message #155513 is a reply to message #155465] Mon, 05 June 2006 09:24 Go to previous messageGo to next message
That's all that was in the file? That doesn't look like a complete
stack trace let alone a complete log entry.
> at
> at
> at
> at
> Thanks
Re: new install for a new user of os x 10.4 [message #155553 is a reply to message #155513] Mon, 05 June 2006 12:56 Go to previous message
Sorry I did leave out a bit. Here is the entire entry
!SESSION 2006-06-05 10:54:16.778
eclipse.buildId=M20060118-1600
java.version=1.5.0_06
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/rafael/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch ppc -keyring
/Users/rafael/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.osgi 2006-06-05 10:54:17.587
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError:
/Applications/eclipse/configuration/org.eclipse.osgi/bundles /63/1/.cp/libswt-pi-carbon-3139.jnilib:
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1660)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:992)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.carbon.OS.<clinit>(OS.java:20)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:8 56)
at org.eclipse.swt.widgets.Display.create(Display.java:836)
at org.eclipse.swt.graphics.Device.<init>(Device.java:118)
at org.eclipse.swt.widgets.Display.<init>(Display.java:676)
at org.eclipse.swt.widgets.Display.<init>(Display.java:667)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:394)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:155)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:128)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:79)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
Thanks again
Rafael
Previous Topic:Word warp in editor
Next Topic:Google Web Toolkit -> Unable to load module entry point
Current Time: Fri Nov 14 23:21:14 EST 2025
Powered by FUDForum. Page generated in 0.28952 seconds
