Home » Newcomers » Newcomers » Eclipse generating errors on quit?
Eclipse generating errors on quit? [message #155436] Sun, 04 June 2006 22:05 Go to next message
Originally posted by: tyrion.thevagabond.net
Hi people!
I'm loving eclipse so far, but one thing is nagging me. When I quit the
application some errors are being generated. It doesn't matter what I do,
I can just open it and close it a couple of minutes later (without opening
any files) and it will still happen.
Could someone shed some light on this problem for me?
This is a copy of the log for one of the sessions where it's happened:
!SESSION 2006-06-05 11:50:22.281
eclipse.buildId=M20060118-1600
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-06-05 11:50:33.355
!MESSAGE While loading class
"net.sourceforge.phpeclipse.PHPeclipsePlugin$3$1", thread "Worker-5" timed
out waiting (5000ms) for thread "Worker-1" to finish starting bundle
"net.sourceforge.phpeclipse". To avoid deadlock, thread "Worker-5" is
proceeding but "net.sourceforge.phpeclipse.PHPeclipsePlugin$3$1" may not
be fully initialized.
!STACK 0
java.lang.Exception: Generated exception.
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:108)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
net.sourceforge.phpeclipse.PHPeclipsePlugin$3.run(PHPeclipse Plugin.java:1182)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ui.workbench 4 0 2006-06-05 11:57:15.980
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.ShellPool$1.widgetDisposed(ShellPool .java:50)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:101)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Widget.releaseWidget(Widget.java:755 )
at org.eclipse.swt.widgets.Control.releaseWidget(Control.java:1 574)
at org.eclipse.swt.widgets.Scrollable.releaseWidget(Scrollable. java:195)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:594)
at org.eclipse.swt.widgets.Canvas.releaseWidget(Canvas.java:117 )
at org.eclipse.swt.widgets.Decorations.releaseWidget(Decoration s.java:782)
at org.eclipse.swt.widgets.Shell.releaseWidget(Shell.java:868)
at org.eclipse.swt.widgets.Widget.releaseResources(Widget.java: 720)
at org.eclipse.swt.widgets.Shell.releaseShells(Shell.java:862)
at org.eclipse.swt.widgets.Shell.releaseWidget(Shell.java:867)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:382)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :441)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:499)
at org.eclipse.jface.window.Window.close(Window.java:321)
org.eclipse.jface.window.ApplicationWindow.close(Application Window.java:291)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1403)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:646)
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:627)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:728)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:726)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:108)
at org.eclipse.ui.internal.Workbench$11.run(Workbench.java:588)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 85)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:52 2)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:713)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:711)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:686)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:643)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:727)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 4)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1649)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3040 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3751 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2756)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2006-06-05 11:57:15.995
!STACK 0
org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed(WorkbenchPartReference.java:151)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:588)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:593)
!ENTRY org.eclipse.ui.workbench 4 2 2006-06-05 11:57:16.73
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:297)
at org.eclipse.swt.widgets.Label.setText(Label.java:486)
com.rohanclan.cfml.views.browser.CFBrowser$4.changed(CFBrows er.java:270)
at org.eclipse.swt.browser.Browser$2.handleEvent(Browser.java:4 52)
org.eclipse.swt.ole.win32.OleEventTable.sendEvent(OleEventTa ble.java:55)
org.eclipse.swt.ole.win32.OleEventSink.notifyListener(OleEve ntSink.java:144)
at org.eclipse.swt.ole.win32.OleEventSink.Invoke(OleEventSink.j ava:119)
at org.eclipse.swt.ole.win32.OleEventSink.access$1(OleEventSink .java:96)
at org.eclipse.swt.ole.win32.OleEventSink$1.method6(OleEventSin k.java:70)
org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:117)
at org.eclipse.swt.internal.win32.OS.VtblCall(Native Method)
org.eclipse.swt.internal.ole.win32.IOleInPlaceObject.InPlace Deactivate(IOleInPlaceObject.java:21)
org.eclipse.swt.ole.win32.OleClientSite.deactivateInPlaceCli ent(OleClientSite.java:524)
org.eclipse.swt.ole.win32.OleClientSite.onDispose(OleClientS ite.java:825)
org.eclipse.swt.ole.win32.OleClientSite.access$1(OleClientSi te.java:821)
org.eclipse.swt.ole.win32.OleClientSite$1.handleEvent(OleCli entSite.java:125)
at org.eclipse.ui.internal.PartPane.dispose(PartPane.java:164)
at org.eclipse.ui.internal.ViewPane.dispose(ViewPane.java:176)
org.eclipse.ui.internal.WorkbenchPartReference.dispose(Workb enchPartReference.java:625)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1439)
org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchP age.java:1431)
at org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory. java:237)
at org.eclipse.ui.internal.Perspective.dispose(Perspective.java :250)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:1494)
org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:763)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1392)
Re: Eclipse generating errors on quit? [message #155765 is a reply to message #155436] Tue, 06 June 2006 08:13 Go to previous messageGo to next message
Originally posted by: eclipse4.rizzoweb.com
Jason B wrote:
> Hi people!
> do, I can just open it and close it a couple of minutes later (without
> opening any files) and it will still happen.
> timed out waiting (5000ms) for thread "Worker-1" to finish starting
> bundle "net.sourceforge.phpeclipse". To avoid deadlock, thread
> "Worker-5" is proceeding but
> "net.sourceforge.phpeclipse.PHPeclipsePlugin$3$1" may not be fully
> initialized.
Some error with the PHPEclipse plugin that you are using. I'm sure they
have a forum of some kind; have you asked there?
Eric
Re: Eclipse generating errors on quit? [message #155829 is a reply to message #155765] Tue, 06 June 2006 10:02 Go to previous messageGo to next message
Originally posted by: cburgess.progressrail.com
Eric Rizzo wrote:
> Jason B wrote:
>> Hi people!
>> the application some errors are being generated. It doesn't matter
>> what I do, I can just open it and close it a couple of minutes later
>> (without opening any files) and it will still happen.
>> initialized.
> Eric
I've been using the PHPEclipse plugin for several weeks now and have
never seen this kind of shutdown failure. You don't have an open Debug
session in progress when you're shutting down do you?
Re: Eclipse generating errors on quit? [message #156691 is a reply to message #155829] Tue, 13 June 2006 20:39 Go to previous message
"Chuck Burgess" <cburgess@progressrail.com> wrote in message
news:e641sp$636$2@utils.eclipse.org...
> Eric Rizzo wrote:
>> Jason B wrote:
>>> Hi people!
>>> !SESSION 2006-06-05
>>> 11:50:22.281 -----------------------------------------------
>>> initialized.
>> Eric
> I've been using the PHPEclipse plugin for several weeks now and have never
> seen this kind of shutdown failure. You don't have an open Debug session
I'm actually using the CFEclipse perspective, and I'm pretty sure I don't
have any debug sessions open (I wouldn't know how, I'm very new to Eclipse,
and I only really want to use it for syntax highlighting and auto completion
to speed up coding).
Previous Topic:Workbench Toolbar Paths Problem
Next Topic:Test
Current Time: Sun Nov 23 00:38:07 EST 2025
Powered by FUDForum. Page generated in 0.23459 seconds
