| Eclipse generating errors on quit? [message #155436] |
Sun, 04 June 2006 22:05   |
Eclipse User  |
Originally posted by: tyrion.thevagabond.net
Hi people!
I'm loving eclipse so far, but one thing is nagging me. When I quit the
application some errors are being generated. It doesn't matter what I do,
I can just open it and close it a couple of minutes later (without opening
any files) and it will still happen.
Could someone shed some light on this problem for me?
This is a copy of the log for one of the sessions where it's happened:
!SESSION 2006-06-05 11:50:22.281
eclipse.buildId=M20060118-1600
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-06-05 11:50:33.355
!MESSAGE While loading class
"net.sourceforge.phpeclipse.PHPeclipsePlugin$3$1", thread "Worker-5" timed
out waiting (5000ms) for thread "Worker-1" to finish starting bundle
"net.sourceforge.phpeclipse". To avoid deadlock, thread "Worker-5" is
proceeding but "net.sourceforge.phpeclipse.PHPeclipsePlugin$3$1" may not
be fully initialized.
!STACK 0
java.lang.Exception: Generated exception.
 org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:108)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
 org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
	at java.lang.ClassLoader.loadClassInternal(Unknown Source)
 net.sourceforge.phpeclipse.PHPeclipsePlugin$3.run(PHPeclipse Plugin.java:1182)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ui.workbench 4 0 2006-06-05 11:57:15.980
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
	at  org.eclipse.ui.internal.ShellPool$1.widgetDisposed(ShellPool .java:50)
 org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:101)
	at  org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
	at  org.eclipse.swt.widgets.Widget.releaseWidget(Widget.java:755 )
	at  org.eclipse.swt.widgets.Control.releaseWidget(Control.java:1 574)
	at  org.eclipse.swt.widgets.Scrollable.releaseWidget(Scrollable. java:195)
	at  org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:594)
	at  org.eclipse.swt.widgets.Canvas.releaseWidget(Canvas.java:117 )
	at  org.eclipse.swt.widgets.Decorations.releaseWidget(Decoration s.java:782)
	at org.eclipse.swt.widgets.Shell.releaseWidget(Shell.java:868)
	at  org.eclipse.swt.widgets.Widget.releaseResources(Widget.java: 720)
	at org.eclipse.swt.widgets.Shell.releaseShells(Shell.java:862)
	at org.eclipse.swt.widgets.Shell.releaseWidget(Shell.java:867)
	at org.eclipse.swt.widgets.Widget.dispose(Widget.java:382)
	at  org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :441)
	at org.eclipse.swt.widgets.Shell.dispose(Shell.java:499)
	at org.eclipse.jface.window.Window.close(Window.java:321)
 org.eclipse.jface.window.ApplicationWindow.close(Application Window.java:291)
 org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1403)
 org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:646)
 org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:627)
	at  org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:728)
	at  org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
	at  org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:726)
	at  org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:108)
	at  org.eclipse.ui.internal.Workbench$11.run(Workbench.java:588)
 org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
	at org.eclipse.core.runtime.Platform.run(Platform.java:783)
	at  org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 85)
	at  org.eclipse.ui.internal.Workbench.access$8(Workbench.java:52 2)
	at  org.eclipse.ui.internal.Workbench$13.run(Workbench.java:713)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:711)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:686)
 org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:643)
	at  org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:727)
	at  org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 4)
 org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
	at  org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
	at  org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1649)
	at  org.eclipse.swt.widgets.Control.windowProc(Control.java:3040 )
	at  org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
	at  org.eclipse.swt.widgets.Display.windowProc(Display.java:3751 )
	at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
	at  org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
	at  org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410)
	at  org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at  org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
	at  org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2756)
	at  org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
	at  org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
 org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
	at  org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
	at  org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
 org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
	at  org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
	at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
	at org.eclipse.core.launcher.Main.run(Main.java:973)
	at org.eclipse.core.launcher.Main.main(Main.java:948)
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2006-06-05 11:57:15.995
!STACK 0
 org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed(WorkbenchPartReference.java:151)
	at  org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:588)
	at  org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:593)
!ENTRY org.eclipse.ui.workbench 4 2 2006-06-05 11:57:16.73
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
	at org.eclipse.swt.SWT.error(SWT.java:2942)
	at org.eclipse.swt.SWT.error(SWT.java:2865)
	at org.eclipse.swt.SWT.error(SWT.java:2836)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
	at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:297)
	at org.eclipse.swt.widgets.Label.setText(Label.java:486)
 com.rohanclan.cfml.views.browser.CFBrowser$4.changed(CFBrows er.java:270)
	at  org.eclipse.swt.browser.Browser$2.handleEvent(Browser.java:4 52)
 org.eclipse.swt.ole.win32.OleEventTable.sendEvent(OleEventTa ble.java:55)
 org.eclipse.swt.ole.win32.OleEventSink.notifyListener(OleEve ntSink.java:144)
	at  org.eclipse.swt.ole.win32.OleEventSink.Invoke(OleEventSink.j ava:119)
	at  org.eclipse.swt.ole.win32.OleEventSink.access$1(OleEventSink .java:96)
	at  org.eclipse.swt.ole.win32.OleEventSink$1.method6(OleEventSin k.java:70)
 org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:117)
	at org.eclipse.swt.internal.win32.OS.VtblCall(Native Method)
 org.eclipse.swt.internal.ole.win32.IOleInPlaceObject.InPlace Deactivate(IOleInPlaceObject.java:21)
 org.eclipse.swt.ole.win32.OleClientSite.deactivateInPlaceCli ent(OleClientSite.java:524)
 org.eclipse.swt.ole.win32.OleClientSite.onDispose(OleClientS ite.java:825)
 org.eclipse.swt.ole.win32.OleClientSite.access$1(OleClientSi te.java:821)
 org.eclipse.swt.ole.win32.OleClientSite$1.handleEvent(OleCli entSite.java:125)
	at org.eclipse.ui.internal.PartPane.dispose(PartPane.java:164)
	at org.eclipse.ui.internal.ViewPane.dispose(ViewPane.java:176)
 org.eclipse.ui.internal.WorkbenchPartReference.dispose(Workb enchPartReference.java:625)
 org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1439)
 org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchP age.java:1431)
	at  org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory. java:237)
	at  org.eclipse.ui.internal.Perspective.dispose(Perspective.java :250)
	at  org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:1494)
 org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:763)
 org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1392)
| Re: Eclipse generating errors on quit? [message #156691 is a reply to message #155829] |
Tue, 13 June 2006 20:39   |
Eclipse User  |
"Chuck Burgess" <cburgess@progressrail.com> wrote in message
news:e641sp$636$2@utils.eclipse.org...
> Eric Rizzo wrote:
>> Jason B wrote:
>>> Hi people!
>>> do, I can just open it and close it a couple of minutes later (without
>>> opening any files) and it will still happen.
>>> !SESSION 2006-06-05
>>> 11:50:22.281 -----------------------------------------------
>>> timed out waiting (5000ms) for thread "Worker-1" to finish starting
>>> bundle "net.sourceforge.phpeclipse". To avoid deadlock, thread
>>> "Worker-5" is proceeding but
>>> "net.sourceforge.phpeclipse.PHPeclipsePlugin$3$1" may not be fully
>>> initialized.
>> Some error with the PHPEclipse plugin that you are using. I'm sure they
>> have a forum of some kind; have you asked there?
>> Eric
> I've been using the PHPEclipse plugin for several weeks now and have never
> seen this kind of shutdown failure.  You don't have an open Debug session
> in progress when you're shutting down do you?
I'm actually using the CFEclipse perspective, and I'm pretty sure I don't
have any debug sessions open (I wouldn't know how, I'm very new to Eclipse,
and I only really want to use it for syntax highlighting and auto completion
to speed up coding).
FUDForum. Page generated in 0.11536 seconds
