Home » Newcomers » Newcomers » Eclipse on Solaris 10
Eclipse on Solaris 10 [message #155127] Fri, 02 June 2006 13:10 Go to next message
Originally posted by: fabian.juarez.gmail.com
Hi!
Today I had download the Eclipse IDE Solaris version but if attempt to
run it the system replies a message, this indicates that the program
will don't run.
> $ ./eclipse
> ./eclipse: no es posible ejecutar (no possible to execute)
> $_
What's necessary to run this program into my Solaris Box...?
Fabián Alejandro Juárez Martínez
Intel Pentium 4 a 3.06 GHz
PCChips M925G
512 MB DDR
DD 40 GB
DVD+RW 4X
Sun Solaris 10 1/05 x86
SunOS helios 5.10 Generic_Patch_118844-30 i86pc i386 i86pc
¡Usando Evolution 1.4.6.330!
Re: Eclipse on Solaris 10 [message #155157 is a reply to message #155127] Fri, 02 June 2006 14:56 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Try chmod +x eclipse. The executable bit may not have been persisted in
the archive file.
- Jeff
Re: Eclipse on Solaris 10 [message #155237 is a reply to message #155157] Fri, 02 June 2006 16:19 Go to previous messageGo to next message
--------------020502030205070207040701
No... the result into graphic!
Jeff Myers escribi
Re: Eclipse on Solaris 10 [message #155245 is a reply to message #155237] Fri, 02 June 2006 16:26 Go to previous messageGo to next message
You're sure you downloaded the version for Solaris on x86, not Solaris
on SPARC?
Other than that, I have no clue.
- Jeff
Re: Eclipse on Solaris 10 [message #155267 is a reply to message #155245] Fri, 02 June 2006 16:38 Go to previous messageGo to next message
From your graphic I see you've downloaded Eclipse 3.1.2, which does not
have a Solaris x86 version available. Download and try Eclipse 3.2 RC6
Solaris (x86/GTK 2) instead.
- Jeff
Re: Eclipse on Solaris 10 [message #155301 is a reply to message #155267] Fri, 02 June 2006 21:28 Go to previous messageGo to next message
Okay! I'll be attempt with the recommended... wait me for comments.
Thanks Jeff!
> - Jeff
PCChips M925G
512 MB DDR
DD 40 GB
DVD+RW 4X
Re: Eclipse on Solaris 10 [message #155482 is a reply to message #155301] Mon, 05 June 2006 01:27 Go to previous message
You recommendation solve my problem... Eclipse works fine!
Thanks!
> Thanks Jeff!
>> not have a Solaris x86 version available. Download and try Eclipse
>> 3.2 RC6 Solaris (x86/GTK 2) instead.
>> - Jeff
PCChips M925G
512 MB DDR
DD 40 GB
DVD+RW 4X
Previous Topic:plug-in help
Next Topic:FileOpen plugin
Current Time: Sat Jul 26 19:54:28 EDT 2025
Powered by FUDForum. Page generated in 0.08940 seconds
