Home » Language IDEs » Java Development Tools (JDT) » IMethodBinding.isSynthetic: propper behaviour?
IMethodBinding.isSynthetic: propper behaviour? [message #14530] Mon, 05 May 2003 21:54 Go to next message
I've created an AST visitor, and upon visiting a ClassInstanceCreation
node I want to determine whether or not the invoked constructor is
explicitly declared in the source code, or if it is a default
constructor.
I thought the IBinding.isSynthetic() method would give me that info, but
it is returning "false" even for classes which do not have explicit
constructor declarations. The javadoc states for isSynthetic:
"Returns whether this binding is synthetic. A synthetic binding is one
that was made up by the compiler, rather than something declared in the
source code."
Is this a bug, or am I misinterpreting the javadoc? If it is not a bug,
is there some other way to determine if the constructor is default?
Ryan
Re: IMethodBinding.isSynthetic: propper behaviour? [message #14709 is a reply to message #14530] Tue, 06 May 2003 05:22 Go to previous messageGo to next message
Synthetic is a special modifier bit used for certain constructs generated by
the compiler (innerclass emulation support, access methods, ...).
This modifier got introduced around 1.1 version, and thus default
constructors were already out.
Also see discussion in bug
http://bugs.eclipse.org/bugs/show_bug.cgi?id=36819
"Ryan Wannop" <wannop@cs.ubc.ca> wrote in message
news:3EB715CB.1A3FF7F1@cs.ubc.ca...
> constructor.
> source code."
> Cheers,
> Ryan
Re: IMethodBinding.isSynthetic: propper behaviour? [message #15048 is a reply to message #14530] Tue, 06 May 2003 09:52 Go to previous message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Mon, 05 May 2003 18:54:19 -0700, Ryan Wannop <wannop@cs.ubc.ca>
If the related ITypeBinding is from an anonymous class, then you know
for sure that its constructor is a default constructor.
In fact, we should update the javadoc to state that isSynthetic() is
returning if the corresponding info in the .class file has a synthetic
attribute.
Olivier
Previous Topic:linked resources & CVS
Next Topic:missing incremental build
Current Time: Mon Nov 17 21:04:35 EST 2025
Powered by FUDForum. Page generated in 0.03495 seconds
