| Unexpected Signal: 11 crash [message #154879] |
Mon, 10 November 2003 08:46 |
Originally posted by: michael.lexi.com
Running Eclipse on Redhat Linux I'm
getting this hs_err_ output after crashes:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4DB0D020
Function=(null)+0x4DB0D020
Library=/usr/lib/libgdk-x11-2.0.so.0
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.gtk.OS.gtk_main_iteration(Native
Method)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1432)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoa
der.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
sorImpl.java:25)
Any ideas? Do I need to update the x11 libs?
FUDForum. Page generated in 0.05213 seconds
