Home » Modeling » GMF (Graphical Modeling Framework) » Quick CreateElement question
Quick CreateElement question [message #154646] |
Wed, 10 October 2007 06:34  |
Originally posted by: trommas.yahoo.com
I create an element in an action like this (this gives an "empty" element):
IElementType type = UemlbaseElementTypes.ClassNode_2002;
ViewAndElementDescriptor viewDescriptor =
new ViewAndElementDescriptor(new CreateElementRequestAdapter(
new CreateElementRequest(type)),Node.class, (
(IHintedType) type).getSemanticHint(),
selectedElement.getDiagramPreferencesHint());
Is there any way to "grab" the newly created element (so I can set it's
properties), or to choose what object is to be created?
(like: ClassNodeImpl dummy = new ClassNodeImpl();
dummy.setName("dummy");
...new CreateElementRequestAdapter(new CreateElementRequest(dummy,
type))...
- I've tried this, no work :(
Tomas
Re: Quick CreateElement question [message #154703 is a reply to message #154646] |
Wed, 10 October 2007 12:11   |
I've simplified it a bit:
CreateElementRequest eReq = new CreateElementRequest
(UemlbaseElementTypes.ClassNode_2002);
ViewAndElementDescriptor viewDescriptor = new ViewAndElementDescriptor(
new CreateElementRequestAdapter(eReq), Node.class,((IHintedType)
type).getSemanticHint(), prefs);
This gives me an empty element, what I would like is to run something like:
ClassNode dummy = new ClassNodeImpl();
CreateElementRequest eReq = new CreateElementRequest (dummy,
Strange that it doesn't work...
Tomas
> type))...
> Tomas
Re: Quick CreateElement question [message #154869 is a reply to message #154715] |
Thu, 11 October 2007 10:00   |
Thanks for helping, but the view variable is always null (the if test
always fails), any ideas?
Tomas
Begoña Moros wrote:
> Hi Tomas,
> you can get the reference of the model element created by means of a
> CreateElementRequest as follows:
> IAdaptable viewAdapter = (IAdaptable) ((List)
> request.getNewObject()).get(0);
> View view = (View) viewAdapter.getAdapter(View.class);
> if (view != null) {
> ModelElement element = (ModelElement) view.getElement();
> Once you get the reference to the model element you should change its
> attributes by means of creating a SetRequest and executing the command:
> this.getDiagramEditDomain().getDiagramCommandStack().execute (new
> ICommandProxy(new SetValueCommand(setRequest)));
> IHIH
> Begoña
> "Tomas Zijdemans" <trommas@yahoo.com> escribió en el mensaje
> news:feitj7$l00$2@build.eclipse.org...
>> like:
>> Thanks,
>> Tomas
>>> element):
>>> type))...
>>> Thanks,
>>> Tomas
Re: Quick CreateElement question [message #154872 is a reply to message #154869] |
Thu, 11 October 2007 10:41   |
I resolved it by using "CreateViewRequest topicRequest =
CreateViewRequestFactory.getCreateShapeRequest.." instead :)
But could anyone tell me how to use setRequests? Or point me to an example
Tomas
> Tomas
> Begoña Moros wrote:
>> Hi Tomas,
>> if (view != null) {
>> IHIH
>> Begoña
>>> like:
>>> Thanks,
>>> Tomas
>>>> element):
>>>> it's properties), or to choose what object is to be created?
>>>> CreateElementRequest(dummy, type))...
>>>> Thanks,
>>>> Tomas
Re: Quick CreateElement question [message #154885 is a reply to message #154876] |
Thu, 11 October 2007 13:13  |
The way I did it earlier didn't work. But everything is fine now. I
struggle to unravel SetReqest.
I guess I should instantiate the SetRequest class with the EObject,
stuctural feature, and Object.
But stuctural features are edges/connections aren't they?
Could you give me an example from your case Begoña?
Tomas
Begoña Moros wrote:
> Tomas,
> are you sure you are creating the request in the right way? I do that as
> follows:
> IElementType type = XXXElementTypes.ModelElement_1001;
> CreateViewRequest request =
> CreateViewRequestFactory.getCreateShapeRequest(
> type,
> this.getDiagramPreferencesHint());
> After that I do what I sent to you in the last post and it works.
> Best regards,
> Begoña
> news:fela9c$1pb$1@build.eclipse.org...
>> Thanks,
>> Tomas
>> Begoña Moros wrote:
>>> Hi Tomas,
>>> if (view != null) {
>>> IHIH
>>> Begoña
>>>> like:
>>>> Thanks,
>>>> Tomas
>>>>> element):
>>>>> type))...
>>>>> Thanks,
>>>>> Tomas
Current Time: Sat Jul 26 02:28:47 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
