Home » Eclipse Projects » Nebula » CTableTree limited to 2048 rows?
CTableTree limited to 2048 rows? [message #14498] Tue, 17 October 2006 22:01 Go to next message
Hi all,
I'm trying to use a CTableTree (with the experimental viewer) to display
a tree from an EMF model. However, I'm unable to display more than 2048
rows in the table. The remaining rows are simply greyed out, as shown on
this screenshot (modified snipplet to display 2050 rows):
http://everest.fit.qut.edu.au/~n4198522/ctabletree.png
Does anyone know why that is so?
cheers,
asgeir
Re: CTableTree limited to 2048 rows? [message #14528 is a reply to message #14498] Wed, 18 October 2006 04:44 Go to previous messageGo to next message
I'm not able to reproduce this on Linux GTK so it may be a bug on the
Windows implementation - can you post a snippet showing this problem?
Asgeir Frimannsson wrote:
> Hi all,
> cheers,
> asgeir
Re: CTableTree limited to 2048 rows? [message #14556 is a reply to message #14528] Wed, 18 October 2006 07:35 Go to previous messageGo to next message
Hi Jeremy,
Here's a simple snipplet reproducing this:
CTableTree ctt =
new CTableTree(shell, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL);
CContainerColumn column1 = new CContainerColumn(ctt, SWT.LEFT);
column1.setText("Column 1");
column1.setWidth(200);
for (int i = 0; i < 2050; i++) {
CTableTreeItem item = new CTableTreeItem(ctt, SWT.NONE);
item.setText(new String[] { "item " + i});
I'm using nebula from eclipse cvs head.
cheers,
asgeir
>> Hi all,
>> display a tree from an EMF model. However, I'm unable to display more
>> than 2048 rows in the table. The remaining rows are simply greyed out,
>> as shown on this screenshot (modified snipplet to display 2050 rows):
>> cheers,
>> asgeir
Re: CTableTree limited to 2048 rows? [message #14585 is a reply to message #14556] Wed, 18 October 2006 10:08 Go to previous messageGo to next message
Chris Gross gave this insight:
> I believe this is a result of using a ScrolledComposite. Widgets have
> size limit on Win and the way ScrolledComposite works requires that
> the inner content size to its full necessary height. So if the size
> of that inner content can only be as large as the Win limit (which I
> think is like 32k pixels but I can't remember). Fixing this problem
> will likely require significant changes to remove the use of
> ScrolledComposite and scroll differently.
Please log a bug for this with [WIN32] in the title. Thanks.
> Hi Jeremy,
> CTableTree ctt =
> cheers,
> asgeir
>>> Hi all,
>>> out, as shown on this screenshot (modified snipplet to display 2050
>>> rows):
>>> cheers,
>>> asgeir
Re: CTableTree limited to 2048 rows? [message #14615 is a reply to message #14585] Thu, 19 October 2006 03:49 Go to previous message
Submitted bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=161518
cheers,
asgeir
>> Hi Jeremy,
>> CTableTree ctt =
>> cheers,
>> asgeir
>>>> Hi all,
>>>> more than 2048 rows in the table. The remaining rows are simply
>>>> greyed out, as shown on this screenshot (modified snipplet to
>>>> display 2050 rows):
>>>> cheers,
>>>> asgeir
Re: CTableTree limited to 2048 rows? [message #566787 is a reply to message #14498] Wed, 18 October 2006 04:44 Go to previous message
> Hi all,
> cheers,
> asgeir
Re: CTableTree limited to 2048 rows? [message #566800 is a reply to message #14528] Wed, 18 October 2006 07:35 Go to previous message
Hi Jeremy,
CTableTree ctt =
cheers,
asgeir
>> Hi all,
>> cheers,
>> asgeir
Re: CTableTree limited to 2048 rows? [message #566824 is a reply to message #14556] Wed, 18 October 2006 10:08 Go to previous message
> Hi Jeremy,
> CTableTree ctt =
> cheers,
> asgeir
>>> Hi all,
>>> rows):
>>> cheers,
>>> asgeir
Re: CTableTree limited to 2048 rows? [message #566845 is a reply to message #14585] Thu, 19 October 2006 03:49 Go to previous message
cheers,
asgeir
>> Hi Jeremy,
>> CTableTree ctt =
>> cheers,
>> asgeir
>>>> Hi all,
>>>> display 2050 rows):
>>>> cheers,
>>>> asgeir
Previous Topic:CTableTree limited to 2048 rows?
Next Topic:PGroup added to Nebula
Current Time: Sat Aug 09 21:11:35 EDT 2025
Powered by FUDForum. Page generated in 0.13417 seconds
