Home » Eclipse Projects » GEF » a question on drag and drop a text from Word editor to Graphical Editor
a question on drag and drop a text from Word editor to Graphical Editor [message #14461] Mon, 22 July 2002 04:55 Go to next message
Originally posted by: tiffany.chen.intech.com.tw
I want to add a drop listener to my Graphical Editor which will receive
text dragged from Word. Actually I am modifing the example
com.ibm.etools.gef.examples.logicdesigner to fit my requirement, but I
can't get the text dragged from Word. I added a System.out.println
command in updateTargetReques to check out the dragged data, but it's
always null.
I also add dragEnter(DropTargetEvent event) and drop(DropTargetEvent
event) methods to updateTargetReques(), but they never get triggered. Why
is that?
Any help would be aprreciated.
Here is my code:
public class LogicEditor
extends GraphicalEditorWithPalette
implements CommandStackListener
protected void initializeGraphicalViewer() {
getGraphicalViewer().setContents(getLogicDiagram());
getGraphicalViewer().addDropTargetListener(
new TextTransferDropTargetListener(getGraphicalViewer(),
TextTransfer.getInstance()));
public class TextTransferDropTargetListener
extends AbstractTransferDropTargetListener
public TextTransferDropTargetListener(EditPartViewer viewer, Transfer
xfer) {
super(viewer, xfer);
protected boolean canHandleDrop(DropTargetEvent event) {
return true;
protected Request createTargetRequest() {
return new NativeDropRequest();
protected NativeDropRequest getNativeDropRequest() {
System.out.println("getNativeDropRequest");
return (NativeDropRequest)getTargetRequest();
protected void updateTargetRequest(){
getNativeDropRequest().setData(getCurrentEvent().data);
System.out.println("updateTargetRequest.data= " + getCurrentEvent
().data);
//the event data is null here
Re: a question on drag and drop a text from Word editor to Graphical Editor [message #14551 is a reply to message #14461] Mon, 22 July 2002 08:19 Go to previous messageGo to next message
Originally posted by: none.ibm.com
The data is always null until the actual drop occurs. This is due to
limitations on some SWT platforms.
The event data will be set only for the very last callback, which I think is
handleDrop or something.
"Tiffany" <tiffany.chen@intech.com.tw> wrote in message
news:ahgham$5mt$1@rogue.oti.com...
> always null.
> is that?
> Here is my code:
> xfer) {
> return true;
> ().data);
Re: a question on drag and drop a text from Word editor to Graphical Editor [message #14730 is a reply to message #14461] Mon, 22 July 2002 10:02 Go to previous messageGo to next message
Tiffany,
Make sure your EditPart has an EditPolicy installed that is similar to
LogicLabelEditPolicy. Also, you can use the GEF debug view to see what's going
on during the drag. If you have the com.ibm.etools.gef.doc.isv plugin, go to
Window... Show View... Other and choose GEF Developer... GEF Debug. Click the
hand icon to see DND messages. If everything is working correctly, you should
see messages similar to these...
37 Drag Enter: com.ibm.etools.gef.dnd.DelegatingDropAdapter@1a5af9f
38 Entered EditPart: LogicLabelEditPart( Label #1 Text=Label )
39 Current listener
com.ibm.etools.gef.examples.logicdesigner.TextTransferDropTa rgetListener @15e538e
40 Drag Over:
41 Drag Over:
42 Drag Over:
43 Drag Over:
44 Drag Leave: com.ibm.etools.gef.dnd.DelegatingDropAdapter@1a5af9f
45 Drag Leave:
46 Drop Accept: com.ibm.etools.gef.dnd.DelegatingDropAdapter@1a5af9f
47 Drop Accept:
48 Drop: com.ibm.etools.gef.dnd.DelegatingDropAdapter@1a5af9f
49 Drop:
50 Exited EditPart: LogicLabelEditPart( Label #1 Text=New Text )
51 Entered EditPart: null
52 Current listener null
> always null.
> is that?
> Here is my code:
> xfer) {
> return true;
> ().data);
Re: a question on drag and drop a text from Word editor to Graphical Editor [message #15602 is a reply to message #14730] Thu, 25 July 2002 02:34 Go to previous message
Thanks for your help. I got it working now.
Tiffany
Previous Topic:starting a connection not from the palette
Next Topic:Delegation of selection
Current Time: Thu Nov 06 20:27:31 EST 2025
Powered by FUDForum. Page generated in 0.03771 seconds
