Home » Eclipse Projects » GEF » Unhandled event loop exception,Reason:,java.lang.NullPointerException
Unhandled event loop exception,Reason:,java.lang.NullPointerException [message #153922] |
Wed, 13 October 2004 15:06  |
Originally posted by: boby.vt.edu
i am trying to build a multipage editor (with one page showing the
graphical viewer and the other a XML based text editor). I have looked
at the Networkeditor and flowlogic example. The problem is that when i
try to add a component (equivalent of activity in the flow example) i
get unhandled event loop exception. Basically i click on the component
in the palette and then move mouse into the viewer (The cursor changes
to "stop sign", instead of the "drop sign") and click inside the viewer.
the stack trace of the error and "stack trace" of what i did is attached
below. Any help in solving this problem is much appreciated
thanks
!SESSION Oct 13, 2004 15:03:00.968
eclipse.buildId=unknown
java.version=1.4.2_05
Command-line arguments: -application org.eclipse.ui.ide.workbench -pdelaunch
!ENTRY org.eclipse.ui 4 4 Oct 13, 2004 15:03:00.968
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Oct 13, 2004 15:03:00.984
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.gef.tools.CreationTool.handleButtonDown(Creation Tool.java:143)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:977)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:201)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(DomainEventDispatcher.java:327)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( LightweightSystem.java:503)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
This is more like a stack trace of what i did till now.
1. i created a plugin using the "plugin with multipage editor" template.
2. Then looking at the NetworkEditor example of IBM Red book, in the
main file XCModelEditor (in example equ is networkeditor.java) removed
page 3 and changed page 2 to call the Editor (ModelEditor). The
XCModelEditor was modeled based on networkeditor and i added things like
MultiPageCommandStackListener, delegatingCommandStackListener,
ISelectionListener, getSharedKeyHandler
3. created the modeleditor by looking at networkpage and
AbstractEditorPage. it has EditDomain, createPartControl (using splitter
as in flow example), createGraphicalViewer (sets a new diagram and
addDropTargetListener), createPaletteViewer, getPaletteRoot (which calls
ModelEditorPaletteFactory), init (which has setSite(site) and
setInput(input))
4. then based on flowexample, i created following files
ComponentImages (to hold images),
In dnd package -> ComponentTemplateTransferDropTargetListener,
In figures package (copied from flow example) -> SubgraphFigure,
In model package -> AbstractComponent, Component,
ComponentElementFactory, ModelComponent (equivalent of activitydiagram,
since i got only components, i dont need StructuredActivity,
ParallelActivity), Transition
In model.commands package (all copied from flow example)->
AddAndAssignSourceCommand, ConnectionCreateCommand,
CreateAndAssignSourceCommand, DeleteCommand, ReconnectSourceCommand,
ReconnectTargetCommand
In parts package -> BottomAnchor, TopAnchor, ComponentPart (abstract),
SimpleComponentPart, StructuredComponentPart (abstract),
ModelComponentPart, DummyLayout, GraphAnimation,
GraphicalEditPartsFactory, GraphLayoutManager, TransitionPart
In policies package -> ComponentNodeEditPolicy,
ComponentSourceEditPolicy, TransitionEditPolicy, XCComponentEditPolicy
(equivalent of ActivityEditPolicy)
in ui package -> ModelEditorPaletteFactory.
Re: Unhandled event loop exception,Reason:,java.lang.NullPointerException [message #154180 is a reply to message #153922] |
Thu, 14 October 2004 16:52   |
Set a breakpoint in CreationTool.handleButtonDown and find out what is null.
It seems the TargetEditPart is. In that case, set a breakpoint in
CreationTool.handleMove() and find out why the target is null. The target
should be properly detected and set when updateTargetUnderMouse() is
invoked.
"Boby George" <boby@vt.edu> wrote in message
news:ckju0j$fi7$1@eclipse.org...
> Hi
> thanks
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
m.java:503)
> at
> at
> at
java:335)
> at
> at
> setInput(input))
Re: Unhandled event loop exception,Reason:,java.lang.NullPointerException [message #157516 is a reply to message #153922] |
Wed, 10 November 2004 03:51  |
Originally posted by: notavalidaddress.notavaliddomain.com
Did you manage to solve this? I have exactly the same problem!
Thanks.
> Hi
> thanks
> !STACK 0
> at
> at
> at
m.java:503)
> at
> at
> at
java:335)
> at
> at
> setInput(input))
Current Time: Sat Jul 26 23:09:05 EDT 2025
Powered by FUDForum. Page generated in 0.25572 seconds
