Home » Newcomers » Newcomers » Starting out in Java
Starting out in Java [message #153902] Wed, 24 May 2006 08:16 Go to next message
Originally posted by: weldon.mac.gmail.com
I installed Eclipse as an experiment in OS Flash, but now I'm moving in to
Java and that pretty much means web services, JSP, servlets, etc... so, if
I read this right, I need to be dealing with J2EE. Fair enough, but
without a compeling reason, I would rather not use 2 IDEs, so I want to
work with Eclipse. I get the impression that means the myEclispse plugin.
Am I correct? Is the plugin worth the cost or should I go with one of the
Sun IDEs? Do I need to download J2EE from Sun as well as the plugin? I'll
neeed a server for windows, what's best?
Re: Starting out in Java [message #153917 is a reply to message #153902] Wed, 24 May 2006 10:14 Go to previous messageGo to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <fe01fe05bf7078601783057c535ae50f$1@www.eclipse.org>,
weldon.mac@gmail.com says...
> Hi
Check out the Eclipse WebTools Project. It's free (open source), and
works fine.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Starting out in Java [message #153947 is a reply to message #153917] Wed, 24 May 2006 18:48 Go to previous messageGo to next message
You asked about servers for Windows. The Web Tools Project works very well
with Tomcat and/or Geronimo, and I am sure many others as well.
-- Mike
"David Kerber" <ns_dkerber@ns_WarrenRogersAssociates.com> wrote in message
news:MPG.1ede2178689b604f98968d@news.eclipse.org...
>> Hi
>> to
>> if
> works fine.
Re: Starting out in Java [message #155717 is a reply to message #153947] Tue, 06 June 2006 07:38 Go to previous message
If you need FULL JEE capability, Tomcat won't do it - it is only partial
JEE. JBoss (www.jboss.org) is the industry standard free J(2)EE server
implementation, although it is a bit more complex than Tomcat.
For a partial J(2)EE server, I prefer Jetty over Tomcat (smaller and
lighter-weight, but just as capable), but that is a matter of taste.
Hope this helps,
Eric
Previous Topic:Runtime error in example code - don't know why
Next Topic:Newbie learning about Eclipse / Java under Windows environment
Current Time: Sun Nov 23 09:41:34 EST 2025
Powered by FUDForum. Page generated in 0.08663 seconds
