Home » Language IDEs » Java Development Tools (JDT) » problem with updating TableTreeViewer using IResourceChangeListener
problem with updating TableTreeViewer using IResourceChangeListener [message #153879] Mon, 12 April 2004 21:14 Go to next message
Originally posted by: lshan.imail.eecs.berkeley.edu
Hi all eclipse masters,
I have TableTreeViewer to display a tree to reflect the stuff on local file
system. I want that view to be automatically updated when a there is a
change in the resources. Thus, i used IResourceChangeListener. Inside
IResourceChangeListener.resourceChanged(), i remove all the TableTreeItem in
that TableTreeViewer and then search for the new ones, then create
TableTreeItems for them.
The problem occurs when i try to remove all TableTreeItems. I got an
SWTException: "Invalid Thread Access". I found out TableTreeItem is only
allowed to be modified by the thread that created it, but the thread that
invokes IResourceChangeListener.resourceChanged() is not that creating
thread. Therefore, all manipulations inside
IResourceChangeListener.resourceChanged() are disallowed.
How can i solve this problem?? Am i taking the wrong approach?? There must
be a way to solve it.
Thank you very much for all your helps.
Lexin
Re: problem with updating TableTreeViewer using IResourceChangeListener [message #155017 is a reply to message #153879] Mon, 19 April 2004 18:03 Go to previous message
Like in Swing in SWT is just one thread listening for user input and
doing all the (re-)drawing. Use Display.(a)syncExec() to execute your
code. You usually obtain that by accessing the current shell.
Sorry, have no Eclipse handy to be more detailed/accurate.
> Lexin
Previous Topic:Quick class open
Next Topic:Code formatting on check-in/commit and check-out/edit for first time?
Current Time: Tue Oct 21 04:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.29405 seconds
