Re: Creation tool for combined figures [message #153871] |
Fri, 05 October 2007 13:00  |
Originally posted by: atoulme.intalio.com
Sorry it is eclipse.modeling.gmf, not eclipse.gmf
Antoine Toulme wrote:
> Hi Marsha,
> I'm not sure we can help you well. You should address the GMF newsgroup
> for such questions. I am adding it in CC so that others can help.
> I'll take a crack at it anyway:
> you should create a Tool (implementing CreationTool I think) and
> override the getCommnand method to make it do whatever you want it to do.
> Then add it in the palette using the PaletteFactory implementation that
> was created for your diagram.
> Hope this helps.
> Antoine
> Marsha wrote:
>> I would like to do something similar as in the BPMN editor but I can't
>> get it.
>> I have two figures. Figure "Step" and figure "Activity". The figure
>> "Step" is a compartment for the figure "Activity".
>> In the ecore model the relation between "Step" and "Activity" is that
>> "StepImplementation" is an aggregation of "Step" and
>> "StepImplementation" is the generalisation of "Activity".
>> <eClassifiers xsi:type="ecore:EClass" name="Step">
>> <eStructuralFeatures xsi:type="ecore:EAttribute"
>> name="autoAbortBehaviour" eType="#//AutoAbortBehaviour"/>
>> name="autoCancelBehaviour" eType="#//AutoCancelBehaviour"/>
>> <eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
>> lowerBound="1" eType="ecore:EDataType
>> http://www.eclipse.org/emf/2002/Ecore#//EString"
>> iD="true"/>
>> name="isCompensation" eType="ecore:EDataType
>> http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
>> <eStructuralFeatures xsi:type="ecore:EAttribute" name="type"
>> eType="#//StepType"/>
>> <eStructuralFeatures xsi:type="ecore:EReference" name="parameter"
>> upperBound="-1"
>> eType="#//StaticParameter" containment="true"/>
>> name="implementation" upperBound="-1"
>> eType="#//StepImplementation" containment="true"/>
>> </eClassifiers>
>> <eClassifiers xsi:type="ecore:EClass" name="StepImplementation">
>> <eStructuralFeatures xsi:type="ecore:EReference" name="cardinality"
>> eType="#//StepCardinality"
>> </eClassifiers>
>> <eClassifiers xsi:type="ecore:EClass" name="Activity"
>> eSuperTypes="#//StepImplementation">
>> eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
>> <eStructuralFeatures xsi:type="ecore:EAttribute" name="function"
>> <eStructuralFeatures xsi:type="ecore:EAttribute" name="version"
>> eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
>> </eClassifiers>
>> <eClassifiers xsi:type="ecore:EClass" name="Flow"
>> </eClassifiers>
>> In my GMF palette I have a Step, Activity and Flow creation tool. If I
>> create a Step I can put an Activity or a Flow implementation in the
>> Step compartment.
>> What I know want is a creation tool say StepActivity which creates
>> direcety a Step with the Activity implementation in the compartment.
>> So I have to define a CreateCommand which creates a Step and puts
>> automatically an Activity inside before desplaying...
>> How can I achieve this?
>> The difference to the BPMN editor is that it is not an Enumeration put
>> an aggregation.
>> Would be great if anyone could help me!
>> Thanks a lot
>> Marsha
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: Creation tool for combined figures [message #154439 is a reply to message #153871] |
Tue, 09 October 2007 11:50  |
Originally posted by: marsha.rohrer.swisscom.com
Hi Antoine,
Thanks for your reply. I already posted the question in the GMF newsgroup,
unfortunately without sucess.
I'm taking the BPMN editor as example, so that is the reason why I thought
that someone may help me.
I'll try your proposition.
Greets,
Marsha
FUDForum. Page generated in 0.03534 seconds
