Home » Eclipse Projects » Eclipse Platform » A zany refactoring question
A zany refactoring question [message #153860] Thu, 06 November 2003 17:21 Go to next message
Originally posted by: johnhkc.earthlink.net
I'd like to know if the following is possible using Eclipse.
This is for use in a code generator.
Imagine I have a piece of Java code that stretches over many lines and
builds a String like this:
String mystr = "the " +
"cow " +
"said " +
"moo " +
"moo " +
"moo " +
I want to write a refactoring routine where the user hilights a line that
will have a condition added. For example, I could highlight the last
"moo" and the refactoring routine would add an IF so that the code changes
to this:
"cow " +
"said " +
"moo " +
"moo ";
if ( someFlag == true )
mystr += "moo ";
mystr += "!";
Is there a way to programmatically parse through the String declaration,
see the last "moo", end the statement before it, surround the last "moo"
with a condition and append the trailing "!" as in the code above?
Re: A zany refactoring question [message #153926 is a reply to message #153860] Thu, 06 November 2003 23:53 Go to previous messageGo to next message
Originally posted by: akiezun.cuthis.mit.edu.andthis
the jdt group would be better for your question
look into ASTRewrite and its friends
it's internal stuff for now but there's work on making it API for 3.0
a.
Re: A zany refactoring question [message #153965 is a reply to message #153860] Fri, 07 November 2003 03:04 Go to previous message
> that will have a condition added. For example, I could highlight the
> last "moo" and the refactoring routine would add an IF so that the
> code changes to this:
> "cow " +
> "said " +
> "moo " +
> "moo ";
> mystr += "moo ";
> mystr += "!";
If the code
"cow " +
"said " +
"moo " +
"moo " +
(someFlag ? "moo " : "") +
would be ok, too (it should be equivalent), this could be easily done using
code templates:
(${condition} ? ${word_selection} : "")
Take care, Ilja
Previous Topic:Using external JARs in a PlugIn
Next Topic:Add Block Comments to Text Editor
Current Time: Mon Jun 23 03:21:58 EDT 2025
Powered by FUDForum. Page generated in 0.25355 seconds
