Home » Eclipse Projects » Eclipse Platform » Unable to start Tomcat 4.1.29 with Eclipse 2.1.2
Unable to start Tomcat 4.1.29 with Eclipse 2.1.2 [message #153811] Thu, 06 November 2003 16:06 Go to next message
Originally posted by: rtjahjono.integra-online.com
Today I upgraded to both Tomcat 4.1.29 and Eclipse 2.1.2 for Windows, and
now I am unable to start Tomcat within Tomcat. When I do, I get the error
message below. I was able to do this with Tomcat 4.1.27 and Eclipse 2.1.1
without any problems.
Any help would be greatly appreciated.
Nov 6, 2003 3:07:55 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on port 8080
Exception during startup processing
java.lang.reflect.InvocationTargetException
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:20 3)
Caused by: java.lang.NoClassDefFoundError:
javax/management/MBeanRegistration
at java.lang.ClassLoader.findBootstrapClass(Native Method)
at java.lang.ClassLoader.findBootstrapClass0(ClassLoader.java:7 09)
at java.lang.ClassLoader.loadClass(ClassLoader.java:284)
at java.lang.ClassLoader.loadClass(ClassLoader.java:282)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.apache.catalina.loader.StandardClassLoader.loadClass(Sta ndardClassLoader.java:941)
org.apache.catalina.loader.StandardClassLoader.loadClass(Sta ndardClassLoader.java:857)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
org.apache.catalina.loader.StandardClassLoader.findClass(Sta ndardClassLoader.java:621)
org.apache.catalina.loader.StandardClassLoader.loadClass(Sta ndardClassLoader.java:958)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
org.apache.coyote.tomcat4.CoyoteConnector.initialize(CoyoteC onnector.java:1097)
org.apache.catalina.core.StandardService.initialize(Standard Service.java:579)
org.apache.catalina.core.StandardServer.initialize(StandardS erver.java:2246)
at org.apache.catalina.startup.Catalina.start(Catalina.java:511 )
at org.apache.catalina.startup.Catalina.execute(Catalina.java:4 00)
at org.apache.catalina.startup.Catalina.process(Catalina.java:1 80)
... 5 more
Re: Unable to start Tomcat 4.1.29 with Eclipse 2.1.2 [message #153821 is a reply to message #153811] Thu, 06 November 2003 16:16 Go to previous messageGo to next message
There is a small change in Tomcat 4.1.29 that prevent the plugin to launch Tomcat successfully.
It will be fix in version 2.2 of the plugin (will be release very soon).
For the moment there is a simple (but not obvious) workaround : select 'Tomcat 5.x' in the plugin preference page and set Tomcat home to your Tomcat 4.1.29 directory.
Bruno
Re: Unable to start Tomcat 4.1.29 with Eclipse 2.1.2 [message #153837 is a reply to message #153821] Thu, 06 November 2003 16:48 Go to previous message
That worked great. Thanks!
Tomcat successfully. It will be fix in version 2.2 of the plugin (will be
release very soon). For the moment there is a simple (but not obvious)
Bruno
Previous Topic:How to a plugin install directory
Next Topic:Problems with help server
Current Time: Tue Nov 04 23:10:32 EST 2025
Powered by FUDForum. Page generated in 0.04654 seconds
