Home » Language IDEs » ServerTools (WTP) » Validation failed to read local xsd schema with servlet2.4 ??
Validation failed to read local xsd schema with servlet2.4 ?? [message #153787] Tue, 27 December 2005 16:15 Go to next message
Hello all,
I tried Eclipse3.1.1+WTP1.0.
The xml catalog file is linked in "Window->Preferences->Web and XML->XML
Catalog". I downloaded all useful xml dtd and xsd files and managed as
local.
Then I create a dynamic web project based on Tomcat 5.0.28. It's failed to
validate the web.xml file. Here is error message:
--- begin ---
Referenced file contains errors
(file:D:/develop/eclipse_ide/xml_schema/webapp/web-app_2_4.x sd). For more
information, right click on the message and select "Show Details..."
--- end ---
But, if I create a Tomcat4.1.30 based project, It's OK.
If I delete local xml catalog setting, all is OK.
The problem doesn't exists in WTP0.7.
Any help?
Re: Validation failed to read local xsd schema with servlet2.4 ?? [message #153884 is a reply to message #153787] Tue, 27 December 2005 09:18 Go to previous messageGo to next message
> --- begin ---
> --- end ---
What key type, key and URI values were you using? I was unable to
reproduce this, but I only had web-app_2_4.xsd mapped locally.
- Nitin
Re: Validation failed to read local xsd schema with servlet2.4 ?? [message #153897 is a reply to message #153884] Wed, 28 December 2005 02:32 Go to previous messageGo to next message
URI: file:D:\develop\eclipse_ide\xml_schema\webapp\web-app_2_4.xs d
Key Type: Schema Location
Key: http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd
j2ee_1_4.xsd and jsp_2_0.xsd are also in the same folder. The error
details show that it failed to read schema document'j2ee_1_4.xsd' and
'jsp_2_0.xsd'.
Thanks for reply.
Re: Validation failed to read local xsd schema with servlet2.4 ?? [message #154780 is a reply to message #153787] Wed, 04 January 2006 11:30 Go to previous message
Audin Chan wrote:
> Hello all,
> local.
> --- begin ---
> --- end ---
> Any help?
This bug has been reported here.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=122102
Previous Topic:add bind key
Next Topic:What happened to pollinate
Current Time: Fri Jul 18 23:32:54 EDT 2025
Powered by FUDForum. Page generated in 0.04036 seconds
