Home » Language IDEs » ServerTools (WTP) » deployable directory
deployable directory [message #153732] Mon, 26 December 2005 09:10 Go to next message
Originally posted by: ranavishal.gmail.com
Hi all I am using wtp 1 can anyone tell me according to below configuration
where is this deployable directory created?
I am confussed between 0.7 and 1 wtp
<project-modules id="moduleCoreId">
<wb-module deploy-name="testing">
<wb-resource deploy-path="/WEB-INF/classes" source-path="/src"/>
<wb-resource deploy-path="/" source-path="/WebContent"/>
<property name="context-root" value="testing"/>
<property name="java-output-path" value="/build/classes/"/>
</wb-module>
</project-modules>
Re: deployable directory [message #153820 is a reply to message #153732] Tue, 27 December 2005 08:15 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Vishal,
the deployable files are put in this dir (depending on your target server):
..metadata\.plugins\org.eclipse.core.resources\.projects\%EA R_PROJECT%\org.eclipse.jst.server.jboss\%WEB_PROJECT%
The sample path comes from a JBoss server definition.
Hope this helps
Wolfgang
> </wb-module>
> </project-modules>
Re: deployable directory [message #155202 is a reply to message #153820] Fri, 06 January 2006 10:38 Go to previous message
Because of this change in where the war is built and deployed from, we are
now getting constant errors when trying to deploy our web projects to a
Weblogic Server. This is due to the now much longer directory name
(approx 140 characters now). The Ant Publisher now fails with this error:
org.eclipse.core.runtime.CoreException[0]: java.lang.Exception: Error
renaming
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.jst.serv er.core\tmp61095.class
to
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.core.res ources\.projects\BXIRW
R7\org.eclipse.jst.server.generic.serverdefinitions\BXIRW
R7\WEB-INF\classes\org\tiaa\irw\integration\util\XMLDisplay\ impl\SEARCHRESTypeImpl$TRTypeImpl$TDTypeImpl$Unmarshaller.cl ass
When trying to manually copy the file and rename it outside of Eclipse, an
error window opens in Windows XP saying that the total file path is too
long - it goes over the 255 character limit.
Even though this is an obvious limitation with Windows, not really a WTP
bug, the change in "staging area" from 0.7.1 to 1.0 has caused this
exception to occur. One fix is to use some other shorter folder path such
as workspace/projectName/.deployables/moduleName instead of
workspace/.metadata/.plugins/org.eclipse.core.resources/.pro jects/projectName/org.eclipse.jst.server.generic.serverdefin itions/
moduleName
This would help minimize this error from occuring.
Wolfgang Knauf wrote:
> Hi Vishal,
..metadata.pluginsorg.eclipse.core.resources.projects%EAR_PR OJECT%org.eclipse.jst.server.jboss%WEB_PROJECT%
> Hope this helps
> Wolfgang
>> <?xml version="1.0" encoding="UTF-8"?>
>> </wb-module>
>> </project-modules>
Previous Topic:Resin 2.1.4
Next Topic:export as EAR leaves out some files
Current Time: Wed Nov 05 10:12:22 EST 2025
Powered by FUDForum. Page generated in 0.02623 seconds
