Home » Archived » Visual Editor (VE) » Problem with JRE 1.1
| Problem with JRE 1.1 [message #14419] |
Mon, 12 January 2004 22:32  |
Originally posted by: huy.swiftdsl.com.au
The VE does not work when I have a JRE 1.1 (JDK 1.1.8), but works fine with
JRE 1.4.1 configured workspace. Is this expected ?
Details
When I try to open a file up in VE it displays an error "Error trying to set
new file into editor", my logs shows
java.version=1.4.1_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:D:/eclipse/
!ENTRY org.eclipse.jem.proxy 2 0 Jan 13, 2004 14:24:42.180
!MESSAGE IWAV0070W Cannot find a proxy implementation to use for project
"sicab."
!ENTRY org.eclipse.ve.java.core 4 0 Jan 13, 2004 14:24:42.210
!MESSAGE Exception
!STACK 0
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createP
roxyFactoryRegistry(JavaVisualEditorPart.java:669)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.i
nitializeForProject(JavaVisualEditorPart.java:1800)
nitialize(JavaVisualEditorPart.java:1705)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1588)
at java.lang.Thread.run(Thread.java:536)
Much appreciated if anyone can shed some light. When I change to JRE 1.4.1,
it works like a charm. I need it to work with JDK 1.1.8 because I'm building
a personal java app.
Huy
| Re: Problem with JRE 1.1 [message #14479 is a reply to message #14449] |
Tue, 13 January 2004 05:01   |
"Joe Winchester" <winchest@uk.ibm.com> wrote in message
news:4003BB15.D831F342@uk.ibm.com...
> Hi Huy,
with
> We only support 1.3 or higher. I'm not even sure that Eclipse itself
supports
> 1.1.8 - if you create just a regular Java class with a main and try and
run it
> does this also crash ?
> Joe
Hi Joe,
Although eclipse does not run on jre 1.1, it does support projects which are
targeted at jre 1.1. I'm not sure what you mean by crash (what crashes), but
the VE can't load the simple class file (as described) into design view. I
don't think it has anything to do with the java source file. For some
reason, the selected JRE for the project is also used to startup the VE in
eclipse and if this is the case, it will not work. This seems strange.
Just to repeat what I said in my first email, if I change my workspace JRE
to 1.4.1, then everything starts to work again. VE even properly parses my
JDK 1.1 source code i.e all java beans and event handlers appear in the
different views.
Until someone helps me out with this, I'd like to share my work around. I
configure my workspace to use the 1.4.1 JRE (or 1.3+ JRE for that matter)
which allows the VE to run normally. I then create a separate ant build
script to compile and jar my project using javac1.1 (adding this to the
eclipse external build tools), then run the resulting jar file using my jre
1.1 (personalJava in my case) separately outside of eclipse (of course you
can get the thing to run as part of the ant script as well).
Hope this helps somebody, yet also hoping that it won't need to.
Huy
| Re: Problem with JRE 1.1 [message #14509 is a reply to message #14479] |
Tue, 13 January 2004 05:17   |
Hi Huy,
Sorry for asking, but I'm a bit curious : why do you want your personnal
application to run on JDK 1.1.8 ?
I mean, if it's a personal java app you should have few constraints, am I
right ?
Besides, SWING performance significantly improved from JDK 1.1 to 1.4
(actually SWING wasn't even part of the JDK 1.1)
"Huy Do" <huy@swiftdsl.com.au> wrote in message
news:bu0fl7$pgf$1@eclipse.org...
> > Hi Huy,
fine
> with
> supports
> run it
> > Joe
> Hi Joe,
are
but
> different views.
jre
> Huy
| Re: Problem with JRE 1.1 [message #15052 is a reply to message #14509] |
Thu, 15 January 2004 08:06  |
Hi Sebastien,
I didn't mean PersonalJava as in java program for personal use, but the
PersonalJava used for PDA applications. With a statement like "I'm building
a personal java app." (from my first post) I'm not surprised of the
misunderstanding, sorry.
Huy
"S
| Re: Problem with JRE 1.1 [message #577397 is a reply to message #14419] |
Tue, 13 January 2004 04:32  |
Hi Huy,
We only support 1.3 or higher. I'm not even sure that Eclipse itself supports
1.1.8 - if you create just a regular Java class with a main and try and run it
Joe
| Re: Problem with JRE 1.1 [message #577426 is a reply to message #14449] |
> Hi Huy,
with
supports
run it
> Joe
Hi Joe,
different views.
Huy
| Re: Problem with JRE 1.1 [message #577448 is a reply to message #14479] |
Hi Huy,
right ?
> > Hi Huy,
fine
> with
> supports
> run it
> > Joe
> Hi Joe,
are
but
> different views.
jre
> Huy
| Re: Problem with JRE 1.1 [message #578315 is a reply to message #14509] |
Hi Sebastien,
Huy
"S
Current Time: Tue Nov 18 09:13:13 EST 2025
Powered by FUDForum. Page generated in 0.06748 seconds
