Home » Newcomers » Newcomers » Problems in migrating j2se to j2me
Problems in migrating j2se to j2me [message #153726] Mon, 22 May 2006 11:01
Originally posted by: brunofernandesbastos.yahoo.com.br
Hi, i'm having problems in migrating j2se to j2me. There is a option that
makes eclipse change the compiler level, i develop using java 5 and my
compiler level is compatible with java 1.3. The problem is that i need to
migrate it to j2me now and when i copy my classes and i remove the j2se
library it appears a lot of error and it's dificult to find what are the
similar classes. I'd like to know how does eclipse do that adaptation,
then if it has a set of similar classes it will be easyer to do the
changes.
Previous Topic:gdb debugger is not working in window xp
Next Topic:Setting up Eclipse for uncommon programming languages
Current Time: Thu Jul 24 11:11:26 EDT 2025
Powered by FUDForum. Page generated in 0.06453 seconds
