Home » Language IDEs » C / C++ IDE (CDT) » HelloWord console app does not appear? Works in debug mode!
HelloWord console app does not appear? Works in debug mode! [message #153590] Fri, 09 September 2005 15:25 Go to next message
Environment:
1) Windows 2000 Pro
2) Cygwin fully installed
3) CDT installed in Eclipse 3.1
It appears that in creating a simple 'Hello World' console application
does not appear to open the windows command window when executed
but appears to work only in debug mode.
This was discovered simply because I saw no console window, because
automatic
build failed (due to still running program) and so I terminated the running
program
within the IDE.
I am assuming that I will need to somehow build this simple program such
that
it somehow knows that the the program is a console window? How do I do
this?
Dan
Re: HelloWord console app does not appear? Works in debug mode! [message #153604 is a reply to message #153590] Fri, 09 September 2005 20:30 Go to previous messageGo to next message
In the simple HelloWorld.c program, I had a getchar() function after the
printf
statement and noticed that flush did not occur. How do I know that? I
entered
a character within the Console window and then saw the "Hello World" output.
Seems that the output is somehow buffered in the Console window of the IDE
Here is the code:
* HelloWorld.c
#include <stdio.h>
int main()
(void) printf("Hello World\n");
(void) printf("Hit any key to terminate this program.\n");
(void) getchar();
return (0);
Also, I tried the cpp version of the code and sheesh, why is it
that the iostream header file is not even located!?!?!? Try this
code as well....
* HelloWorld.cpp
#include <iostream> // <== Error found here
using namespace std;
int main()
cout << "Hello, World!" << endl;
Error reported:
Severity Description Resource In Folder Location Creation Time
1 C/C++ Indexer Problem: Preprocessor Inclusion not found: iostream in file:
E:\Projects\Eclipse\WorkspaceJB\HelloWorld\HelloWorld.cpp on line: 5.
HelloWorld.cpp HelloWorld line 5 September 9, 2005 5:13:29 PM
Re: HelloWord console app does not appear? Works in debug mode! [message #153650 is a reply to message #153604] Sun, 11 September 2005 12:48 Go to previous messageGo to next message
Originally posted by: dschaefer.qnx.com
> printf
> entered
This is a known problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=102043
Doug.
> Here is the code:
> * HelloWorld.c
> #include <stdio.h>
> int main()
> (void) getchar();
> return (0);
> code as well....
> * HelloWorld.cpp
> int main()
> Error reported:
Re: HelloWord console app does not appear? Works in debug mode! [message #155060 is a reply to message #153650] Mon, 26 September 2005 13:31 Go to previous messageGo to next message
Originally posted by: rowck001.bigpond.net.au
I also found this console problem (in Windows) and my solution could help
newbies;
I add a program input wait function, eg. getchar() at the end of the main
function in an application and then execute by double-clicking the exe
from either the debug or release options in the outline and use the dos
box window to view the output
hope this helps
Re: HelloWord console app does not appear? Works in debug mode! [message #155121 is a reply to message #155060] Tue, 27 September 2005 12:22 Go to previous message
The point of the problem is that the CDT IDE is not working correctly and
needs to be fixed. There is a bug report filed for this problem.
"Craig Rowlands" <rowck001@bigpond.net.au> wrote in message
news:bad086395e1d5ec2a8e1d5f0e683cc0c$1@www.eclipse.org...
> newbies;
> hope this helps
Previous Topic:managed make building only 1 file instead of all of them
Next Topic:Debugging - no variables
Current Time: Mon Nov 03 01:04:31 EST 2025
Powered by FUDForum. Page generated in 0.08901 seconds
