Home » Language IDEs » C / C++ IDE (CDT) » Compiling one compile unit
Compiling one compile unit [message #153516] Fri, 09 September 2005 10:58 Go to next message
Is there any way in a managed make project to compile just one compile
unit, i.e., one .cpp file? This would really be handy. (Any IDE should
be able to do this.)
Re: Compiling one compile unit [message #153579 is a reply to message #153516] Fri, 09 September 2005 12:09 Go to previous messageGo to next message
Would creating a custom make target do this? I dunno - I've never tried.
Re: Compiling one compile unit [message #153601 is a reply to message #153579] Fri, 09 September 2005 19:34 Go to previous messageGo to next message
Originally posted by: martin.proctophantasmist.cjb.net
>> should be able to do this.)
But there is no way to do that in a managed project is there? (i.e to
execute "make path/file.o" from the IDE ) I'm greatly interested in the
answer too.
thanks.
Re: Compiling one compile unit [message #153833 is a reply to message #153601] Tue, 13 September 2005 11:10 Go to previous messageGo to next message
Apparently, the answer is no.
John Boncek
JBoncek@Hunter.Com
Re: Compiling one compile unit [message #153848 is a reply to message #153833] Tue, 13 September 2005 12:50 Go to previous message
Originally posted by: fireonyoursleeve.hotmail.com
In the managed build system extensibility doc (in the cdt help doc) it talks
about the following:
2.1.6 Building a Configuration
The user can build projects from within the Eclipse/CDT user interface, or
from a command line that can be placed in a batch/script file.
The user can build the currently active configuration, or select a different
set of configurations to build.
The user can rebuild an individual resource separate from building the
entire project.
But from "select a different set" on is marked in red which indicates that
it hasn't been implemented yet. I assume that a similar issue is tracked in
bugzilla as not yet implemented, but I haven't dug thru that stuff yet.
"John Boncek" <JBoncek@Hunter.Com> wrote in message
news:53d1775daf7c10d5981fbe9319b1bd04$1@www.eclipse.org...
> John Boncek
> JBoncek@Hunter.Com
Previous Topic:Windows: does cygwin have to be in my PATH?
Next Topic:Add watchpoint
Current Time: Sun Nov 09 06:37:39 EST 2025
Powered by FUDForum. Page generated in 0.04087 seconds
