| Need help to set up David Fischer's Webcam software for development [message #153473] |
Fri, 19 May 2006 19:49 |
Hi Folks,
I am trying to setup David Fischer's Webcam software on Eclipse and it
appears that the problem in running it, is that I am unable to get Eclipse
to recognize and find the main() function in in the class it refers to,
order
build and run.
David Fischer's Webcam software has basically two parts; (1) the
java source/class applications and (2) the html code for which a
java-based http webserver will execute both the html/applet and
the webcam java software based on JMF.
I am able to setup all the parts in a J2EE perspective, to define the
classpath locations, and the arguments needed but when I try to
build/RUN the applications, I get an error message:
"Could not find the main class. Program will exit" and the messages
in the colsole window:
java.lang.NoClassDefFoundError: VideoToAppletServer
Exception in thread "main"
I can run this program outside of eclipse by executing a
windows BAT file with the following command:
java VideoToAppletServer -htmlroot "WebContent/htmlroot"
If anyone has any suggestions for me to try, please let me know!
Kind regards,
Dan
FUDForum. Page generated in 0.09081 seconds
