Home » Archived » Test and Performance Tools Platform (TPTP) » HTTP Generate Wizard
HTTP Generate Wizard [message #14354] Wed, 06 April 2005 14:19 Go to next message
Originally posted by: akuhn.arcor.de
using hyades 3.2 i tried to implement my own Arbiter. Of course would be
easy to replace the DefaultTestArbiter in a generate Java Source from
a HTTP URL Test, but i wanted to try to write my own Code Generator.
I searched the source tree for the Files and found
org.eclipse.hyades.test.http.internal.codegen.GenTestSuite which seems
to generate the Java Source of the TestSuite. Looking back in the call
tree, i also found HttpGenerator and HttpGenerateWizard. It seems, that
i hava to implement my own GenerateWizard to be able to generate my own
code, is that right ?
For testing i defined a second entry in
plugins/org.eclipse.hyades.test.http_3.2.0/plugin.xml of
<generateWizard
name="%GEN_WTITLE"
type="org.eclipse.hyades.test.http.junit.testSuite"
icon="icons/full/ctool16/generate_wiz.gif"
description="%GEN_WDESC"
class=" org.eclipse.hyades.test.http.internal.junit.wizard.HttpGener ateWizard "
extension="testsuite">
</generateWizard>
and just change name and description. I hoped in the
Workbench->Properties->Test->Test Associations i could add the new
generateWizard.
Can someone help me on this ? How can i implement my own HTTP URL Test
Java Code Generator ?
Andi
Re: HTTP Generate Wizard [message #14600 is a reply to message #14354] Fri, 08 April 2005 13:28 Go to previous messageGo to next message
Andreas,
As you suspect, to create a new HTTP Generator, you must create an extension
of HttpGenerator and HttpGenerateWizard, as well as create a new extension:
<extension
point="org.eclipse.hyades.test.ui.generateWizards">
<generateWizard
icon="icons/full/obj16/http_generate_wiz.gif"
class=" org.eclipse.hyades.test.tools.ui.http.internal.junit.wizard. HttpGener
ateWizard2"
description="Description"
name="Generator Title"/>
</extension>
I have verified that if the new class (in my example, HttpGenerateWizard2)
exists, it WILL show up in the Test Associations preference page. If you
set your new Generator to the default, it will generate using the Generate
menu action.
I believe that when the preference page is populated, the classname is also
checked (and the duplicity of it). This could explain why your test of just
changing the name & description failed.
It may also interest you that GenTestSuite.java is create using the JET
builder. The files in the templates\ directory are used to generate that
java class. These template files should be much easier to read &
reverse-engineer. It's not required to use JET for a new generator,
however. For more information, start here:
http://www.eclipse.org/articles/Article-JET/jet_tutorial1.ht ml
Of course, you could always just edit the generated code.
Hope this helps,
Jeff Nevicosi
IBM
"Andreas Kuhn" <akuhn@arcor.de> wrote in message
news:d319d5$gll$1@news.eclipse.org...
> <generateWizard
> name="%GEN_WTITLE"
> </generateWizard>
> generateWizard.
> Andi
Re: HTTP Generate Wizard [message #14692 is a reply to message #14600] Sat, 09 April 2005 09:41 Go to previous messageGo to next message
Hi Jeff,
thanks for the info.
Unfortunatly i cannot find the templates directory you mentioned.
Where is it located ?
Thanks in advance,
Andi
Jeff Nevicosi wrote:
> Andreas,
> <extension
> <generateWizard
> ateWizard2"
> </extension>
> menu action.
> Hope this helps,
> Jeff Nevicosi
> IBM
>>Hi,
>><generateWizard
>> name="%GEN_WTITLE"
>> </generateWizard>
>>generateWizard.
>>Thanks,
>>Andi
Re: HTTP Generate Wizard [message #14721 is a reply to message #14692] Mon, 11 April 2005 00:03 Go to previous messageGo to next message
Andreas,
In Hyades 3.3 and earlier, the 'templates' directory is located directly off
the org.eclipse.hyades.test.http. There are also dependent files within the
'templates' directory within org.eclipse.hyades.test.java.
In TPTP 4.0, the templates directory has been moved and renamed:
in org.eclipse.hyades.test.tools.ui: "templates_http"
in org.eclipse.hyades.test.tools.core: "templates_java" and
"templates_manual"
JN
news:4257DB96.4040604@arcor.de...
> Hi Jeff,
> Thanks in advance,
> Andi
> > Andreas,
extension
extension:
> > <extension
> > <generateWizard
> > ateWizard2"
> > </extension>
you
Generate
> > menu action.
also
just
that
> > Hope this helps,
> > Jeff Nevicosi
> > IBM
> >>Hi,
> >><generateWizard
> >> name="%GEN_WTITLE"
> >> </generateWizard>
> >>generateWizard.
> >>Thanks,
> >>Andi
Re: HTTP Generate Wizard [message #14779 is a reply to message #14721] Mon, 11 April 2005 09:43 Go to previous messageGo to next message
One additional point, which I may not have been clear on:
The templates directory is available only in the source code. If you
install the TPTP runtime binaries only, you will not find these JET
templates.
Jeff Nevicosi
IBM Rational
"Jeff Nevicosi" <nevicosi@us.ibm.com> wrote in message
news:d3ctbl$ded$1@news.eclipse.org...
> Andreas,
off
the
> "templates_manual"
> JN
Re: HTTP Generate Wizard [message #49488 is a reply to message #14600] Sat, 07 January 2006 09:35 Go to previous messageGo to next message
Hi Jeff,
there seems to be a change since TPTP 4.1. The GenerateWizard Class is
deprecated and the JavaDoc says, it is replaced by the auto-sync feature.
What exactly is this auto-sync, and how can i use it to generate my own
TestSourceCode based on a TestCase ?
Andi
> Andreas,
> <extension
> <generateWizard
> ateWizard2"
> </extension>
> menu action.
> Hope this helps,
> Jeff Nevicosi
> IBM
>>Hi,
>><generateWizard
>> name="%GEN_WTITLE"
>> </generateWizard>
>>generateWizard.
>>Thanks,
>>Andi
Re: HTTP Generate Wizard [message #67017 is a reply to message #49488] Tue, 18 April 2006 14:47 Go to previous messageGo to next message
Hi all,
anyone has a hint on how to create own GenerateWizard using the new
auto-sync feature ?
Andi
Andreas Kuhn wrote:
> Hi Jeff,
> Andi
>>Andreas,
>><extension
>><generateWizard
>>ateWizard2"
>></extension>
>>menu action.
>>Hope this helps,
>>Jeff Nevicosi
>>IBM
>>>Hi,
>>><generateWizard
>>> name="%GEN_WTITLE"
>>> </generateWizard>
>>>generateWizard.
>>>Thanks,
>>>Andi
Re: HTTP Generate Wizard [message #86622 is a reply to message #67017] Tue, 07 November 2006 07:58 Go to previous messageGo to next message
I'm interested too.
Another question: Who long will the deprecated interface be available in the framework?
Greetings
Holger
Andreas Kuhn schrieb:
> Hi all,
> auto-sync feature ?
> Andi
> Andreas Kuhn wrote:
>> Hi Jeff,
>> Thanks,
>> Andi
>>> Andreas,
>>> <extension
>>> <generateWizard
>>> ateWizard2"
>>> </extension>
>>> menu action.
>>> Hope this helps,
>>> Jeff Nevicosi
>>> IBM
>>>> Hi,
>>>> <generateWizard
>>>> name="%GEN_WTITLE"
>>>> </generateWizard>
>>>> generateWizard.
>>>> Thanks,
>>>> Andi
Re: HTTP Generate Wizard [message #89292 is a reply to message #86622] Mon, 04 December 2006 07:00 Go to previous message
Holger,
TPTP supports deprecated API for a minimum of two full releases.
PS
"Holger Machens" <machens@informatik.fh-wiesbaden.de> wrote in message
news:eipvu2$gi4$1@utils.eclipse.org...
> I'm interested too.
> the framework?
> Greetings
> Holger
>> Hi all,
>> auto-sync feature ?
>> Andi
>> Andreas Kuhn wrote:
>>> Hi Jeff,
>>> feature.
>>> Thanks,
>>> Andi
>>>> Andreas,
>>>> extension
>>>> extension:
>>>> <extension
>>>> <generateWizard
>>>> ateWizard2"
>>>> </extension>
>>>> you
>>>> Generate
>>>> menu action.
>>>> also
>>>> just
>>>> that
>>>> Hope this helps,
>>>> Jeff Nevicosi
>>>> IBM
>>>>> Hi,
>>>>> be
>>>>> that
>>>>> own
>>>>> <generateWizard
>>>>> name="%GEN_WTITLE"
>>>>> </generateWizard>
>>>>> generateWizard.
>>>>> Thanks,
>>>>> Andi
Previous Topic:How can I avoid a time-out in executing an automated GUI test?
Next Topic:HTTP Test: error converting .rec file in .testsuite file
Current Time: Sun Nov 09 02:30:39 EST 2025
Powered by FUDForum. Page generated in 0.07881 seconds
