Home » Eclipse Projects » Eclipse Platform » any use iContract with Ant? I have problem on iDoclet!!
any use iContract with Ant? I have problem on iDoclet!! [message #152845] Tue, 04 November 2003 14:59 Go to next message
Originally posted by: manchi.singnet.com.sg
I just downloaded iDoclet library, and trying to run it with Ant but
encountered a problem! can u help?
I use to the following in build.xml :
<!-- Creates the API documentation with iDoclet -->
<target name="javadocs" depends="prepare-src" description="Generates the
API documentation">
<mkdir dir="${build.javadocs}"/>
<javadoc
packagenames="com.bekk.*"
sourcepath="${build.src}"
destdir="${build.javadocs}"
<doclet name="iContract.doclet.Standard"
path="${lib.dir}/iDoclet.jar">
<param name="-author"/>
<param name="-use"/>
</doclet>
<classpath refid="compile-classpath"/>
</javadoc>
</target>
I encountered the Error message:
javadocs:
[javadoc] Generating Javadoc
[javadoc] Javadoc execution
[javadoc] javadoc: In doclet class iContract.doclet.Standard, method
optionLe
ngth has thrown an exception java.lang.reflect.InvocationTargetException
[javadoc] java.lang.IllegalAccessError: tried to access field
com.sun.tools.do
clets.HtmlWriter.configuration from class iContract.doclet.Standard
[javadoc] at
iContract.doclet.Standard.configuration(Standard.java:54)
[javadoc] at
iContract.doclet.Standard.optionLength(Standard.java:210)
[javadoc] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[javadoc] at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce s
sorImpl.java:39)
[javadoc] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe t
hodAccessorImpl.java:25)
[javadoc] at java.lang.reflect.Method.invoke(Method.java:324)
[javadoc] at
com.sun.tools.javadoc.DocletInvoker.invoke(DocletInvoker.jav a
:193)
[javadoc] at
com.sun.tools.javadoc.DocletInvoker.optionLength(DocletInvok e
r.java:118)
[javadoc] at
com.sun.tools.javadoc.Start.parseAndExecute(Start.java:275)
[javadoc] at com.sun.tools.javadoc.Start.begin(Start.java:121)
[javadoc] at com.sun.tools.javadoc.Main.execute(Main.java:41)
[javadoc] at com.sun.tools.javadoc.Main.main(Main.java:31)
[javadoc] 1 error
Re: any use iContract with Ant? I have problem on iDoclet!! [message #152939 is a reply to message #152845] Wed, 05 November 2003 03:14 Go to previous messageGo to next message
I think iDoclet is not compatible with latest JDK versions. Try with
JDK 1.3.1
-Boris
> API documentation">
> <javadoc
> </doclet>
> </javadoc>
> </target>
> javadocs:
> optionLe
> com.sun.tools.do
> [javadoc] at
> [javadoc] at
> Method)
> [javadoc] at
> sorImpl.java:39)
> [javadoc] at
> [javadoc] at
> :193)
> [javadoc] at
> r.java:118)
> [javadoc] at
> [javadoc] 1 error
Re: any use iContract with Ant? I have problem on iDoclet!! [message #153002 is a reply to message #152939] Wed, 05 November 2003 09:02 Go to previous message
yes, I do not use iDoclet now, instead of that, I try to specify custom
tags in <javadoc> tag! it works fine now!
I would like to share my setting with u friends:
API documentation">
<javadoc
source="1.4"
packagenames="bone.*"
destdir="${build.javadocs}">
<tag name="pre" scope="all" description="Precondition:" />
<tag name="post" scope="all" description="Precondition:" />
<tag name="inv" scope="all" description="invariant:" />
<tag name="invariant" scope="all" description="invariant:" />
</javadoc>
</target>
> JDK 1.3.1
> -Boris
>> iDoclet -->
>> the API documentation">
>> <javadoc
>> </doclet>
>> </javadoc>
>> </target>
>> javadocs:
>> method optionLe
>> com.sun.tools.do
>> [javadoc] at
>> [javadoc] at
>> Method)
>> [javadoc] at
>> sorImpl.java:39)
>> [javadoc] at
>> [javadoc] at
>> :193)
>> [javadoc] at
>> r.java:118)
>> [javadoc] at
>> [javadoc] 1 error
Previous Topic:TreeViewer refresh not visible
Next Topic:automatically switching to custom debug perspective with 3.0M4
Current Time: Fri Nov 07 00:31:57 EST 2025
Powered by FUDForum. Page generated in 0.44334 seconds
