Home » Newcomers » Newcomers » Adding a menu item to File>New
Adding a menu item to File>New [message #152771] Tue, 16 May 2006 11:04 Go to next message
I have created a new editor and would like to make it available within a new
category via the File>New drop-down menu. For example File>New>My
Category...
When the user clicks My Category..., they will see the item for launching my
editor. Eventually there will be other items there for other editors. An
example of this is when you select File>New>Example... So basically, I am
looking for the most elegant solution for adding the category to the
File>New menu.
thanks alot - Barry
Re: Adding a menu item to File>New [message #152811 is a reply to message #152771] Tue, 16 May 2006 13:08 Go to previous messageGo to next message
All about extension points and extensions :-)
See
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/extension-points/org_eclipse_ui_n ewWizards.html
HTH
Darins
"Barry Dresdner" <barry.dresdner@softwareagusa.com> wrote in message
news:e4cpmc$vh3$1@utils.eclipse.org...
> new category via the File>New drop-down menu. For example File>New>My
> Category...
> my editor. Eventually there will be other items there for other editors.
> An example of this is when you select File>New>Example... So basically, I
> am looking for the most elegant solution for adding the category to the
> File>New menu.
> thanks alot - Barry
Re: Adding a menu item to File>New [message #152817 is a reply to message #152811] Tue, 16 May 2006 13:23 Go to previous messageGo to next message
Thank you Darin for the link.
Using this information, I have been able to create a new category and my
selection correctly appears under the category. Now the next step is to get
my category to appear under the File>New drop-down. I assume this can be
done by assigning a parent category (parentCategory) that will point to that
menu. Do you know how I can find out what the category is for the File>New
menu?
regards - Barry
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:e4d0tn$lpi$1@utils.eclipse.org...
> See
> HTH
> Darins
>> Category...
>> I am looking for the most elegant solution for adding the category to the
>> File>New menu.
>> thanks alot - Barry
Re: Adding a menu item to File>New [message #152914 is a reply to message #152817] Wed, 17 May 2006 04:17 Go to previous messageGo to next message
>menu?
See org.eclipse.ui.perspectiveExtensions extension-point.
Dani
>regards - Barry
>>See
>>HTH
>>Darins
>>>Hi,
>>>Category...
>>>File>New menu.
>>>thanks alot - Barry
Re: Adding a menu item to File>New [message #152990 is a reply to message #152914] Wed, 17 May 2006 12:02 Go to previous message
Thanks Dani!!
Barry
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:e4em6s$89g$3@utils.eclipse.org...
>>get my category to appear under the File>New drop-down. I assume this can
>>be done by assigning a parent category (parentCategory) that will point to
>>that menu. Do you know how I can find out what the category is for the
>>File>New menu?
> Dani
>>regards - Barry
>>>See
>>>HTH
>>>Darins
>>>>Hi,
>>>>Category...
>>>>launching my editor. Eventually there will be other items there for
>>>>other editors. An example of this is when you select File>New>Example...
>>>>So basically, I am looking for the most elegant solution for adding the
>>>>category to the File>New menu.
>>>>thanks alot - Barry
Previous Topic:stored procedure
Next Topic:Console interaction with classes
Current Time: Mon Nov 24 04:40:33 EST 2025
Powered by FUDForum. Page generated in 0.26856 seconds
