Home » Eclipse Projects » JFace » hide the parent node in treeviewer
hide the parent node in treeviewer [message #14327] Sun, 14 June 2009 03:00 Go to next message
Hello All,
I want to hide the parent node from treeviewer.
The treeviewer structure looks like this now.
-DocumentRoot(parent node)
+-Tree1
---item1
---item2
+-Tree2
---item3
---item4
+-Tree3
---item1
---item2
but i dont want that treeviewer will show the documentroot node(parent),
but it will strat from the child nodes of documentroot(which are muliples)
and looks like this..
Tree1
---item1
---item2
Tree2
---item3
---item4
Tree3
---item1
---item2
how can i do this.
Thanks in advance.
Gaurav
Re: hide the parent node in treeviewer [message #15439 is a reply to message #14327] Fri, 19 June 2009 12:56 Go to previous message
Originally posted by: TheRealHawk.Freenet.de
Simply set the DocumentRoot as input to your Viewer and your ContentProvider
should do the rest, because the input is not visible.
Markus
"gaurav dubey" <gauravd2@kpitcummins.com> schrieb im Newsbeitrag
news:9633469a7d0e205bfad59ce0171df49a$1@www.eclipse.org...
> Hello All,
> +-Tree1
> ---item1
> ---item2
> +-Tree2
> ---item3
> ---item4
> +-Tree3
> ---item1
> ---item2
> Tree1
> ---item1
> ---item2
> Tree2
> ---item3
> ---item4
> Tree3
> ---item1
> ---item2
> how can i do this.
> Thanks in advance.
> Regards
> Gaurav
Previous Topic:Views And Eclipse Icons
Next Topic:Tree column resize problem on OS X
Current Time: Sun Jul 13 17:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.24814 seconds
