problem with null layout [message #152589] |
Mon, 15 May 2006 09:20  |
Originally posted by: bdavid01.gmail.com
I am using Visual Editor to create a new JPanel object.
When setting the layout to FlowLayout, everything is fine and the Panel is
shown when the application is run.
However if I choose to specify a null layout, although the components show
up in Visual Editor, the JPanel is empty when the application is run.
Can anybody help me on this ?
THanks,
Ben
Re: problem with null layout [message #153695 is a reply to message #152735] |
Mon, 22 May 2006 09:26  |
Hi, I have found out the answer,
you need to specify the prefered size and set the bounds of the panel, the
Panel won't show otherwise ...
FUDForum. Page generated in 0.28481 seconds
