Home » Eclipse Projects » DSDP - Target Management » "./server.pl" does not exist
"./server.pl" does not exist [message #14297] Thu, 30 August 2007 08:08 Go to next message
Originally posted by: johanna.bostrom.gmail.com
I am trying to connect to a remote Unix server, and I am reading the
instructions at the RSE User guide - Connecting to a remote Linux or Unix
server. In the chapter: "To start the server manually" there is a command
"perl ./server.pl [port]", but I get an error message that the file does
not exist.
(In the rseserver-2.0.0.1-linux.tar package the file exists, but not in
the reserver-2.0.0.1-unix.tar.)
How can I solve this issue?
Johanna
Re: "./server.pl" does not exist [message #14314 is a reply to message #14297] Mon, 03 September 2007 09:19 Go to previous message
Hello Johanna,
in the server-unix package, you do
sh ./server.sh
instead. Unfortunately it does not allow you to specify
a fixed port, you'll have to take what it proposes. This
is known bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=164300
I'd appreciate if you could file a bug against RSE documentation. It
should say that in the server-unix package, server.sh is to be run
instead of server.pl
For not being able to specify the port, this should be really easy to
fix if you read the code of the Linux server.pl and do the same in the
server.sh script. I'd appreciate a patch if you'd like to fix this.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> Unix server. In the chapter: "To start the server manually" there is a
> command "perl ./server.pl [port]", but I get an error message that the
> file does not exist.
> Best regards,
> Johanna
Re: "./server.pl" does not exist [message #570066 is a reply to message #14297] Mon, 03 September 2007 09:19 Go to previous message
Hello Johanna,
sh ./server.sh
Martin Oberhuber
> Best regards,
> Johanna
Previous Topic:"./server.pl" does not exist
Next Topic:terminal view in an RCP application
Current Time: Sat Nov 08 11:40:17 EST 2025
Powered by FUDForum. Page generated in 0.03964 seconds
