| "./server.pl" does not exist [message #14297] |
Thu, 30 August 2007 08:08  |
Originally posted by: johanna.bostrom.gmail.com
I am trying to connect to a remote Unix server, and I am reading the
instructions at the RSE User guide - Connecting to a remote Linux or Unix
server. In the chapter: "To start the server manually" there is a command
"perl ./server.pl [port]", but I get an error message that the file does
not exist.
(In the rseserver-2.0.0.1-linux.tar package the file exists, but not in
the reserver-2.0.0.1-unix.tar.)
How can I solve this issue?
Johanna
| Re: "./server.pl" does not exist [message #14314 is a reply to message #14297] |
Mon, 03 September 2007 09:19  |
Hello Johanna,
in the server-unix package, you do
sh ./server.sh
instead. Unfortunately it does not allow you to specify
a fixed port, you'll have to take what it proposes. This
is known bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=164300
I'd appreciate if you could file a bug against RSE documentation. It
should say that in the server-unix package, server.sh is to be run
instead of server.pl
For not being able to specify the port, this should be really easy to
fix if you read the code of the Linux server.pl and do the same in the
server.sh script. I'd appreciate a patch if you'd like to fix this.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> Unix server. In the chapter: "To start the server manually" there is a
> command "perl ./server.pl [port]", but I get an error message that the
> file does not exist.
> Best regards,
> Johanna
| Re: "./server.pl" does not exist [message #570066 is a reply to message #14297] |
Hello Johanna,
sh ./server.sh
Martin Oberhuber
> Best regards,
> Johanna
FUDForum. Page generated in 0.02902 seconds
