Using CDT in Another Eclipse Plugin - [message #152459] |
Fri, 26 August 2005 20:37  |
I am trying to include the CDT in my plugin so that I can leverage some
of its features. I am using Eclipse 3.1 and CDT 3.0. I installed CDT
through the update feature - not with zip files. My eclipse install can
find and use the CDT without error and the software manager reports no
problems. However, when I add any or all cdt plugins to my plugins
"Required Plug-ins" list and try to launch, neither my plugin or CDT
load in the newly launched configuration and I get an error saying
"Missing required bundle org.eclipse.cdt_0.0.0." Also, the software
manager in the new window reports various problems with the CDT install.
Has anyone else had this problem? I believe that this is the correct
way to add CDT for use in another plugin. If not, please let me know.
thanks,
adam
Re: Using CDT in Another Eclipse Plugin - [message #152569 is a reply to message #152459] |
Mon, 29 August 2005 11:47  |
Perhaps you could check first if the problem is caused by your plugin, or
by
the way you installed the CDT plugins. Thus in the Debug/Run launch
configuration=>'Plug-ins' tab deselect your own plugin in the Workspace
Plug-ins list. If that launches ok, check your plugin.xml and manifest
file.
FUDForum. Page generated in 0.03135 seconds
