Home » Newcomers » Newcomers » Eclipse Software Updates
Eclipse Software Updates [message #152369] Fri, 12 May 2006 20:48 Go to next message
Originally posted by: public-mail2.nyc.rr.com
Maybe this is obvious but I haven't found a confirmation...
Currently I use the following version of eclipse
Help -> About Eclipse SDK
Version: 3.1.1
Build id: M20050929-0840
I have tried to update my version of eclipse..
Software Updates -> Find & Install.. ect.
I have tried multiple times & noticed the latest eclipse version is
Eclipse SDK 3.1.2, but my original version never updates.
Install/Update Valid updates is set to equivalent.
Is there any way to update the SDK version w.o. performing
a complete download.
Thanks.
Re: Eclipse Software Updates [message #152537 is a reply to message #152369] Sun, 14 May 2006 20:50 Go to previous messageGo to next message
per
http://www.eclipse.org/newsportal/article.php?id=8925&gr oup=eclipse.newcomer#8925
"....you could update within a release, but couldn't update from
one release to the next.
If you want 3.1.2 or 3.2, you'll need to go install those, not
try to update to them."
Is this confirmed & is there any plans to modify this behavior in the
future?
It seems problematic to customize one release only to have to start from
scratch when the next one arrives, or is there a way to mitigate this.
I've looked for info on this but haven't found any. Any input would be
appriciated. Thanks.
Re: Eclipse Software Updates [message #152628 is a reply to message #152369] Mon, 15 May 2006 13:10 Go to previous messageGo to next message
> Help -> About Eclipse SDK Version: 3.1.1
> Thanks.
Upgrading from 3.1.1 to 3.1.2 should be handled by the Update Manager.
I'm pretty sure I've done exactly that on my home machine.
In any case, this page and those it links to might help you:
http://eclipsewiki.editme.com/Upgrading
Using the advice there it is not a big deal to migrate between different
Eclipse installations.
Hope this helps,
Eric
Re: Eclipse Software Updates [message #152856 is a reply to message #152628] Wed, 17 May 2006 01:24 Go to previous message
Eric, this was exactly what I was looking for.
http://www.eclipse.org/eclipse/platform-releng/updatesfor3.1 .1.html
Many thanks.
Previous Topic:Unable to use Visual Editor
Next Topic:t
Current Time: Thu Nov 27 19:38:32 EST 2025
Powered by FUDForum. Page generated in 0.10379 seconds
