Home » Eclipse Projects » Orbit » Can't org.jdom with Ganymede
Can't org.jdom with Ganymede [message #14284] Tue, 23 September 2008 07:40 Go to next message
Originally posted by: mickael.istria.openwide.fr
I'm using Ganymede (build I20080609-1311), and I'd like to use jdom in
our plugin (JWT).
I saw that org.jdom was included in orbit, however, i don't succeed to
reference it as a dependency in our plugin.xml editor, everything
happens as if org.jdom were not here, but I checked im my
eclipse/plugins folder, and org.jdom is installed. For other orbit
plugin (javax.wsdl, org.uddi4j...), there is not problem.
Do you know what could cause this problem?
Thanks in advance
Mickael
Re: Can't org.jdom with Ganymede [message #15119 is a reply to message #14284] Tue, 04 November 2008 01:41 Go to previous messageGo to next message
Originally posted by: david_williams.linux.vnet.ibm.com
Mickael Istria wrote:
> Hello,
> our plugin (JWT).
> Thanks in advance
> Mickael
Hopefully you've found an answer by now? But do you have it in your
target, or in the workspace?
In PDE target, or in dev. env. is probably easiest.
Re: Can't org.jdom with Ganymede [message #15135 is a reply to message #15119] Wed, 05 November 2008 04:12 Go to previous messageGo to next message
Hello David,
JWT currently includes the jdom jar file into the plugin itself, but I
would like to replace this jar by a dependency to the org.jdom plugin
provided by Orbit (seen on http://wiki.eclipse.org/Orbit_Bundles).
And I can not find this plug-in in my development environment of Eclipse
whereas I can find several other plugins that are part of Orbit.
The Eclipse I have is the Ganymede JEE, to which I added PDE (and other
few things).
I took a look at other colleagues Eclipse environments and it looks like
they do not either have the org.jdom plugin. May org,jdom have been
"forgotten" in Galileo?
Mickael
>> Hello,
>> our plugin (JWT).
>> Thanks in advance
>> Mickael
Re: Can't org.jdom with Ganymede [message #15167 is a reply to message #15135] Wed, 05 November 2008 08:18 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hello, Mickael,
There is no assurance that all of the Orbit bundles will be included in
Eclipse releases, whether Ganymede packages or individual projects.
Indeed, there are probably a few that are not even used by any Eclipse
projects.
The Orbit bundles are included in the features of Eclipse projects that
use them, on an as-needed basis. If none of the Eclipse projects that
your project requires includes the JDOM bundle, then you will need to
incorporate it into your own feature. It is a relatively simple
procedure, as outlined on the Orbit Wiki:
http://wiki.eclipse.org/Easy_Bake_Builds_with_Orbit_Bundles
HTH,
Christian
> Hello David,
> few things).
> Regards
> Mickael
>>> Hello,
>>> in our plugin (JWT).
>>> to reference it as a dependency in our plugin.xml editor, everything
>>> Thanks in advance
>>> Mickael
Re: Can't org.jdom with Ganymede [message #15199 is a reply to message #15167] Wed, 05 November 2008 09:59 Go to previous message
Hi Christian,
Thank you for your help. I thought that Orbit was a set of plugins that
were automatically included with PDE.
I'll take a look at the wiki page you pointed me.
Thanks again
Mickael
Christian W. Damus a écrit :
> Hello, Mickael,
> projects.
> HTH,
> Christian
>> Hello David,
>> Eclipse whereas I can find several other plugins that are part of Orbit.
>> other few things).
>> like they do not either have the org.jdom plugin. May org,jdom have
>> been "forgotten" in Galileo?
>> Regards
>> Mickael
>>>> Hello,
>>>> Thanks in advance
>>>> Mickael
Re: Can't org.jdom with Ganymede [message #564529 is a reply to message #14284] Tue, 04 November 2008 01:41 Go to previous message
> Hello,
> our plugin (JWT).
> Thanks in advance
> Mickael
Re: Can't org.jdom with Ganymede [message #564561 is a reply to message #15119] Wed, 05 November 2008 04:12 Go to previous message
Hello David,
few things).
Mickael
>> Hello,
>> our plugin (JWT).
>> Thanks in advance
>> Mickael
Re: Can't org.jdom with Ganymede [message #564587 is a reply to message #15135] Wed, 05 November 2008 08:18 Go to previous message
Hello, Mickael,
projects.
HTH,
Christian
> Hello David,
> few things).
> Regards
> Mickael
>>> Hello,
>>> Thanks in advance
>>> Mickael
Re: Can't org.jdom with Ganymede [message #564617 is a reply to message #15167] Wed, 05 November 2008 09:59 Go to previous message
Hi Christian,
Thanks again
Mickael
> Hello, Mickael,
> projects.
> HTH,
> Christian
>> Hello David,
>> other few things).
>> Regards
>> Mickael
>>>> Hello,
>>>> Thanks in advance
>>>> Mickael
Previous Topic:How to set up com.ibm.icu bundles within local workspace
Next Topic:JSR166 (java.util.concurrent) backport for Orbit
Current Time: Sat Jul 26 00:15:24 EDT 2025
Powered by FUDForum. Page generated in 0.15295 seconds
