xml dataset on unix file system (org.eclipse.birt.report.data.oda.xml.dataSet) [message #152203] |
Mon, 10 April 2006 06:11  |
I've got some problems to retreive data from a
org.eclipse.birt.report.data.oda.xml.dataSet on a linux machine.
Everything goes fine on my development env., but as I deploy on the linux
machine (the paths are changed by my deployment script), it doesn't shown
the list based on my xml dataset. (where should I find logs?)
Could tou explain what are the
data.oda.xml.FILELIST,
data.oda.xml.dataSet.XML_FILE,
and data.oda.xml.dataSet.XPATHTEXT for?
Gilles
xml dataset on unix file system and logging level [message #152308 is a reply to message #152203] |
Mon, 10 April 2006 12:30   |
I don't see any error in the log, who only logs SEVERE issues (alltrough
the BIRT_VIEWER_LOG_LEVEL context parameter of the web.xml is set to OFF
How can I set the log level? in the web.xml? Can I use OFF, SEVERE,
WARNING, INFO, CONFIG, FINE, FINER, FINEST and ALL for the
BIRT_VIEWER_LOG_LEVEL context parameter?
Gilles
FUDForum. Page generated in 0.03751 seconds
