Home » Eclipse Projects » GEF » GraphicalEditorWithFlyoutPalette
GraphicalEditorWithFlyoutPalette [message #151500] Mon, 20 September 2004 15:36 Go to next message
Originally posted by: james.willans.xactium.com
My palette is currently implemented using GraphicalEditorWithPalette,
however I would like to upgrade this to use
GraphicalEditorWithFlyoutPalette. I thought this would be a matter of
extending a different class and implementing the abstract method
getPalettePreferences(), however I've run into difficulties. I get a null
pointer exception in createPaletteViewerProvider() because
getGraphicalViewer() returns null at that point. Should I be doing
something that I'm not?
Thanks.
James
Re: GraphicalEditorWithFlyoutPalette [message #151507 is a reply to message #151500] Mon, 20 September 2004 18:52 Go to previous messageGo to next message
That's right, the PaletteViewerProvider is created before the graphical
viewer (look at
GraphicalEditorWithFlyoutPalette#createPartControl(Composite )). Why do you
need the graphical viewer for the PaletteViewerProvider?
"James Willans" <james.willans@xactium.com> wrote in message
news:cinbfg$6n0$1@eclipse.org...
> Thanks.
> James
Re: GraphicalEditorWithFlyoutPalette [message #151513 is a reply to message #151500] Mon, 20 September 2004 21:16 Go to previous messageGo to next message
The architecture is slightly different because the palette must be created
over and over as it changes locations.
> Thanks.
> James
Re: GraphicalEditorWithFlyoutPalette [message #151534 is a reply to message #151507] Tue, 21 September 2004 04:28 Go to previous messageGo to next message
Pratik,
I don't require it, but the body of createPaletteViewerProvider() in the
implementation of GraphicalEditorWithFlyoutPalette requires it:
protected PaletteViewerProvider createPaletteViewerProvider() {
return new PaletteViewerProvider(getGraphicalViewer().getEditDomain());
Thanks.
James
> viewer (look at
> > Thanks.
> > James
Re: GraphicalEditorWithFlyoutPalette [message #151568 is a reply to message #151534] Tue, 21 September 2004 10:45 Go to previous messageGo to next message
That was fixed a while back to: return new
PaletteViewerProvider(getEditDomain());
You can override the method and make this change yourself, or you can move
to the latest GEF integration build.
news:ciooml$94n$1@eclipse.org...
> Pratik,
> Thanks.
> James
> > viewer (look at
you
null
> > > Thanks.
> > > James
Re: GraphicalEditorWithFlyoutPalette [message #151594 is a reply to message #151568] Tue, 21 September 2004 12:01 Go to previous messageGo to next message
Pratik,
Thanks I have now got it working. Just a quick question, I would like to
get rid of the palette's title "Palette" and just have the two lines
shown. However when I change the externalised string to "" it looks odd
because a space is left between the two halfs of the line. Is there any
way of having unbroken lines when the string is ""?
James
> > Pratik,
> > Thanks.
> > James
> > > viewer (look at
> you
> null
> > > > Thanks.
> > > > James
Re: GraphicalEditorWithFlyoutPalette [message #151602 is a reply to message #151594] Tue, 21 September 2004 12:22 Go to previous messageGo to next message
Not unless you plan to copy the flyout-related classes. I'd recommend
against it, of course. We want all different GEF palettes to look the same
for the end-user.
news:cipj8d$33i$1@eclipse.org...
> Pratik,
> James
move
> > > Pratik,
the
> > > return new
> > > Thanks.
> > > James
graphical
> > > > viewer (look at
do
> > you
matter of
get a
> > null
doing
> > > > > Thanks.
> > > > > James
Re: GraphicalEditorWithFlyoutPalette [message #151626 is a reply to message #151602] Tue, 21 September 2004 15:42 Go to previous messageGo to next message
So James, open a bugzilla requesting that ALL palettes not display "Palette"
title when expanded. We'll check with our UI experts for a ruling on this.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cipk82$5eq$1@eclipse.org...
same
> for the end-user.
Re: GraphicalEditorWithFlyoutPalette [message #151640 is a reply to message #151626] Tue, 21 September 2004 18:46 Go to previous messageGo to next message
Will do. Just for clarification - You can change the word "Palette" since
the string is externalised.
James
> same
> > for the end-user.
Re: GraphicalEditorWithFlyoutPalette [message #151647 is a reply to message #151640] Tue, 21 September 2004 18:52 Go to previous message
Bug: 74493
> James
"Palette"
> > same
> > > for the end-user.
Previous Topic:How to run GEF examples
Next Topic:how do i use org.eclipse.gef.ui.parts.TreeViewer
Current Time: Fri Jul 18 22:39:29 EDT 2025
Powered by FUDForum. Page generated in 0.05491 seconds
