Home » Language IDEs » ServerTools (WTP) » Adding a Runtime Classpath to a project when a nonWeb facet is installed...
Adding a Runtime Classpath to a project when a nonWeb facet is installed... [message #151499] Mon, 12 December 2005 15:16
Originally posted by: rnaranjo1.NOSPAM.earthlink.net
I added the following to my plugin.xml so that I could state that this
runtime's classpath should be added to my project's classpath if my facet
gets installed.
<extension
point="org.eclipse.wst.common.project.facet.core.runtimes">
<supported>
<runtime-component
id="org.eclipse.jst.server.tomcat"
version="5.0"/>
<facet
id="MyFacet.id"
version="1.0"/>
</supported>
</extension>
However, the code in
org.eclipse.jst.server.core.internal.RuntimeClassPathProvide r.getClassPathEn
tries(final IProjectFacetVersion fv) method
seems to interfere with this definition since it only allows the
classpathentry to be added if the facet is one of these types:
if (WEB_FACET.equals(pf) || EJB_FACET.equals(pf) || EAR_FACET.equals(pf) ||
UTILITY_FACET.equals(pf) || CONNECTOR_FACET.equals(pf) ||
APP_CLIENT_FACET.equals(pf)) {
String s = rc.getProperty(RuntimeBridge.CLASSPATH);
if (s == null || s.length() == 0)
return null;
IClasspathEntry cpentry = JavaCore.newContainerEntry(new Path(s));
return Collections.singletonList(cpentry);
Can anyone help with this? I don't understand the purpose of the above
extension point if the code is implemented as in the above method.
Rosa
Previous Topic:Publishing problems with RC1 & RC2
Next Topic:JSEditor
Current Time: Wed Oct 08 03:26:12 EDT 2025
Powered by FUDForum. Page generated in 0.04013 seconds
