| Want Own Perspective to be activeted by eclipse itself [message #151362] |
Wed, 10 May 2006 01:35 |
I have developed a simple plug-in with only one extension point i.e.
org.eclipse.ui.perspectives to develop my own customized perspective.
(Here I have populated two views from other perspectives by defining them
in createInitialLayout method in my respective perspective class).
It works very well as long as I test that plug-in as run-time workbench in
eclipse.
But what I want that of my plug-in along with customized perspective to be
activated by eclipse itself once I put that of my plug-in into eclipses
plug-in directory (yes, I start eclipse with clean command to make that
plug-in recognize by eclipse).
After following such required steps
I can see my plug-in activated by
eclipse by showing my own perspective in open perspective option from
windows menubar. But when I am going to open that of perspective I get
error like problems opening perspective
org.eclipse.cdt.cradle.ui.perpspective (i.e. the path where my perspective
class resides)
So, where I am wrong to make my perspective activated by eclipse itself ?
content of .log file is like :
!SESSION 2006-05-10 11:00:08.946
eclipse.buildId=I20050627-1435
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 2006-05-10 11:00:30.794
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.cdt.cradle.ui (112).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.cdt.cradle.ui.UiPlugin for bundle org.eclipse.cdt.cradle.ui is
invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:149)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:629)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:230)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:127)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1375)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:896)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:887)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:3051)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:3049)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:91)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:331)
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:346)
org.eclipse.ui.actions.PerspectiveMenu$3.runWithEvent(Perspe ctiveMenu.java:108)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
... 53 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.cdt.cradle.ui.UiPlugin
FUDForum. Page generated in 0.09360 seconds
