Home » Language IDEs » Java Development Tools (JDT) » User Libraries promlem with M8
User Libraries promlem with M8 [message #151166] Sat, 27 March 2004 14:20 Go to next message
I'm testing the M8 new user libraries feature, but I'm in trouble.
My test:
1. Window->Preferences->Java->User Libraries->New
2. User Library Name: "HSQLDB"
3. Add Jars -> "X:\HSQLDB\LIB\HSQLDB.JAR"
4. OK
5. File->New->Project->Java Project->Project Name: "MyProject"
6. Libraries->Add Library->User Library->"HSQLDB"
7. Finish
8. File->New->Package->TestUL
9. File->New->Class->HSQLDB
10. I write:
try {
Class.forName("org.hsqldb.jdbcDriver");
} catch (ClassNotFoundException e) {
System.out.println("HSQLDB JDBC Driver not found.");
System.exit(1);
11. Run->Java Application: "HSQLDB JDBC Driver not found."
If I add the HSQLDB.jar by hand to the class path, all works.
Is this a bug, I'm doing something wrong?
Francesc
Re: User Libraries promlem with M8 [message #151805 is a reply to message #151166] Wed, 31 March 2004 07:13 Go to previous messageGo to next message
Can you have a look at the class path that was used when launching? To
do that, select the process and select 'Properties' from the context menu)
Please file a bug so this doesn't get forgotten
Martin
Francesc Rosés wrote:
> Hello,
> My test:
> 4. OK
> 7. Finish
> 10. I write:
> try {
> System.exit(1);
> Francesc
Re: User Libraries promlem with M8 [message #154600 is a reply to message #151805] Fri, 16 April 2004 07:35 Go to previous messageGo to next message
Martin,
I've been seeing the same behaviour. The new user libraries in M8 are
something I've been waiting for -- so I converted all of my old library-only
projects over to them straight away. Problem is at runtime -- the
configuration doesn't see the user libraries in its classpath.
WORKAROUND: Mark all the user libraries for export, then adding the project
*again* to the launch configuration's "User Entries" classpath.
I was about to enter a bug report, but found your 56530. Do you think the
problem you describe there is the source of this problem? If not, I'll file
a new bug.
Colin Cooper
"Martin Aeschlimann" <martin_aeschlimann@ch.ibm.com> wrote in message
news:c4ecbe$nhu$1@eclipse.org...
> Martin
> Francesc Ros
Re: User Libraries promlem with M8 [message #159460 is a reply to message #154600] Wed, 19 May 2004 11:13 Go to previous message
Originally posted by: daniel.megert.gmx.net
Colin Cooper wrote:
>Martin,
>a new bug.
I suggest to file a new bug report since currently we are quite busy
i.e. bug reports will get attention but we might not be up to date
reading newsgroups.
Dani
> Colin Cooper
>>Martin
>>>Hello,
>>> My test:
>>> 4. OK
>>> 7. Finish
>>> 10. I write:
>>> try {
>>> System.exit(1);
>>> Thanks,
>>> Francesc
Previous Topic:Is anyone able to use the AST for modiyfing not opened files in the Java editor?
Next Topic:Can't create project with overlapping directories and CVS
Current Time: Mon Jul 21 21:57:30 EDT 2025
Powered by FUDForum. Page generated in 0.25506 seconds
