Home » Newcomers » Newcomers » SWT in Palette
SWT in Palette [message #151163] Mon, 08 May 2006 16:49 Go to next message
Originally posted by: Fred_Griffith.hotmail.com
I am trying to create a UI using the SWT, but it is not showing up in the
Palette. I am not seeing SWT containers or components section in the
Palette.
Re: SWT in Palette [message #151172 is a reply to message #151163] Mon, 08 May 2006 17:03 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Are you talking about using the Visual Editor? If so, did you manually
add the SWT jars to your project - because that won't work. Instead
remove those jars, then create a new Visual Class based off of Composite
or Shell and the SWT Library will be added to your project
automatically, and the SWT palette entries will show in the editor.
Hope this helps,
- Jeff
> the Palette. I am not seeing SWT containers or components section in the
> Palette.
Re: SWT in Palette [message #151189 is a reply to message #151172] Mon, 08 May 2006 17:38 Go to previous message
Perfect thanks.
Previous Topic:Delete Workspace
Next Topic:Javax.Servlet
Current Time: Sun Nov 23 02:17:26 EST 2025
Powered by FUDForum. Page generated in 0.08786 seconds
