Unable to create report [message #14144] |
Fri, 04 March 2005 09:18 |
I have installed GEF, EMF, and BIRT on Fedora Core 3 machine, however, I
am unable to create a report. Following instructions from the tutorial I
create a new reports project, then create a new report. Once I have chosen
the report style, in this case a blank report, I click finish and Eclipse
crashes. I have included the log from the crash below. I am running
Eclipse 3.0.1, and as I mentioned the GEF and EMF requirements were met.
After Eclipse has crashed I close the workbench, and attempt to restart
Eclipse, but am unable to do. If I remove the BIRT plugins from the plugin
directory I can restart Eclipse.
!SESSION Mar 04, 2005 09:11:26.947
eclipse.buildId=M200409161125
java.version=1.4.2_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.ui 4 4 Mar 04, 2005 09:11:26.948
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Mar 04, 2005 09:11:26.948
!MESSAGE No more handles (java.lang.UnsatisfiedLinkError:
/home/daniel/compopt/eclipse/plugins/org.eclipse.swt.g
tk_3.0.1/os/linux/x86/libswt-mozilla-gtk-3063.so:
/home/daniel/compopt/eclipse/plugins/org.eclipse.swt.gtk_3.0 .1
/os/linux/x86/libswt-mozilla-gtk-3063.so: undefined symbol:
_ZN9nsCStringC1Ev)
!STACK 0
org.eclipse.swt.SWTError: No more handles (java.lang.UnsatisfiedLinkError:
org.eclipse.swt.gtk_3.0.1/os/linux/x86/libswt-mozilla-gtk-30 63.so:
pse.swt.gtk_3.0.1/os/linux/x86/libswt-mozilla-gtk-3063.so: undefined
symbol: _ZN9nsCStringC1Ev)
at org.eclipse.swt.SWT.error(SWT.java:2717)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:119)
org.eclipse.birt.report.designer.internal.ui.editors.preview .PreviewEditor.createPartControl(PreviewE
ditor.java:259)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:120)
org.eclipse.birt.report.designer.ui.editors.ReportEditor.cre atePreviewPage(ReportEditor.java:829)
org.eclipse.birt.report.designer.ui.editors.ReportEditor.cre atePages(ReportEditor.java:814)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:187)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:196)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:290)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:121 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:59)
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:266)
org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:694)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:683)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:779)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:582)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:570)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2244)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2177)
org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2169)
org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2156)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2151)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:299)
org.eclipse.birt.report.designer.internal.ui.wizards.NewRepo rtWizard$3.run(NewReportWizard.java:430)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2572)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2301)
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:136)
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:262)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
org.eclipse.birt.report.designer.internal.ui.wizards.NewRepo rtWizard.performFinish(NewReportWizard.ja
va:141)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:609)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:305)
org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:954)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2595)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2298)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:163)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.ui 4 4 Mar 04, 2005 09:11:26.952
!MESSAGE *** SWT nested exception
!ENTRY org.eclipse.ui 4 0 Mar 04, 2005 09:11:26.952
!MESSAGE
/home/daniel/compopt/eclipse/plugins/org.eclipse.swt.gtk_3.0 .1/os/linux/x86/libswt-mozilla-gtk-3063.so:
undefin ed symbol: _ZN9nsCStringC1Ev
!STACK 0
la-gtk-3063.so: undefined symbol: _ZN9nsCStringC1Ev
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1495)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:116)
ditor.java:259)
va:141)
FUDForum. Page generated in 0.02698 seconds
