Home » Eclipse Projects » GEF » dynamical loading/adding of pallettes ? editing of pallette items
dynamical loading/adding of pallettes ? editing of pallette items [message #150825] Tue, 14 September 2004 12:45 Go to next message
Originally posted by: dyx.gmx.net
I need to implement a gef editor which can add/load pallettes.
Has anyone done this before?
How about editing the pallette. Is it possible to add/delete new
items/models?
Thanks for any advice,
a newbie
Re: dynamical loading/adding of pallettes ? editing of pallette items [message #150827 is a reply to message #150825] Tue, 14 September 2004 12:53 Go to previous messageGo to next message
Right-click the palette in the logic example, and select "Customize."
"frank" <dyx@gmx.net> wrote in message news:ci7699$4a3$1@eclipse.org...
> items/models?
> a newbie
Re: dynamical loading/adding of pallettes ? editing of pallette items [message #150894 is a reply to message #150827] Wed, 15 September 2004 04:45 Go to previous messageGo to next message
I have seen that. It allows for customization.
I have also taken a look at the source from logic example
and at org.eclipse.gef.ui.palette.customize and the different
PaletteEntryFactory classes
provided.
But I don't see how I can create a new palette with that.
I mean like load one from a file.
frank
PS: On another note: Is the GEF API on the web somehere?
The Help system is running very slow on my machine.
"Pratik Shah" <ppshah@us.ibm.com> schrieb im Newsbeitrag
news:ci77f4$6go$1@eclipse.org...
> > Hi,
> > items/models?
> > a newbie
Re: dynamical loading/adding of pallettes ? editing of pallette items [message #150902 is a reply to message #150894] Wed, 15 September 2004 09:27 Go to previous message
Originally posted by: gaslade.yahoo.com
The Palette is just another GEF editor with a model and edit parts
driving it. You could create a palette manager object whose job it is to
build the palette entries and return the PaletteRoot object with the
entries in it. When you need to dynamically change the palette contents
( add/remove entries ) the palette manager would simply add or remove
children of the PaletteRoot object.
I do this in my editor...my editor listens for project nature changes
and when one happens tells the palette manager to update. The palette
manager changes what the palette contains to what is appropriate for the
project natures.
> provided.
> frank
>>>Hi,
>>>items/models?
>>>a newbie
Previous Topic:Draw2D Anchor Change Location Question
Next Topic:Outline View
Current Time: Tue Jul 08 14:31:13 EDT 2025
Powered by FUDForum. Page generated in 0.27290 seconds
