Home » Archived » Voicetools » java in voicexml
java in voicexml [message #14127] Wed, 31 May 2006 04:03 Go to next message
Originally posted by: la1.informatik.uni-ulm.de
Hallo very one ,
i want to use java in VoiceXML tool can i do that , for example
?xml version="1.0" encoding="ISO-8859-1"?>
<vxml version="2.0" xmlns="http://www.w3.org/2001/vxml">
<var name="hi" expr="'Hello World!'"/>
<form id="say_hi">
<block>
<prompt><value expr="hi"/></prompt>
<goto next="#say_goodbye"/>
</block>
</form>
<form id="say_goodbye">
<block>
Goodbye!
</block>
somthing in java
to have values from database
</form>
</vxml>
if one can do that Pl. one examlpe
loiy
Re: java in voicexml [message #14163 is a reply to message #14127] Wed, 31 May 2006 20:21 Go to previous messageGo to next message
Sorry, no. VoiceXML scripting and scope and variable semantics is firmly
specified on ECMAScript. See the VoiceXML specification
(http://www.w3.org/TR/voicexml20/#dml5).
You can use the <data> tag or some other construct to interact with a
Java-implemented external application that can deliver results to the
VoiceXML application. But you cannot embed Java code inside the VoiceXML.
-- Mike Greenawalt
"loiy Ababneh" <la1@informatik.uni-ulm.de> wrote in message
news:3fd3e6ed438f8e68150a14751f62f38c$1@www.eclipse.org...
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> somthing in java to have values from database
> </form>
> </vxml>
> loiy
Re: java in voicexml [message #14216 is a reply to message #14163] Tue, 20 June 2006 16:46 Go to previous messageGo to next message
Originally posted by: paul.rubenstein.glenayre.com
Hi Loiy,
What you are probably looking for is something like a JSP. You will need
a webserver (such as tomcat) to execute the JSP. You can then produce
something like:
<?xml version="1.0" encoding="ISO-8859-1"?>
<form id="say_hi">
<block>
</block>
</form>
<block>
<prompt>
// JAVA Scriptlet
System.out.println("Goodbye!");
</prompt>
</block>
</form>
</vxml>
> -- Mike Greenawalt
Re: java in voicexml [message #17446 is a reply to message #14216] Wed, 07 February 2007 09:36 Go to previous messageGo to next message
Originally posted by: avtpuser.gmail.com
Hi Paul,
Is there a mechanism to achieve something similar to your response (JSP),
using VTP-GUI?
I am using the VTP Preview build.
"paul rubenstein" <paul.rubenstein@glenayre.com> wrote in message
news:pan.2006.06.20.20.46.03.865345@glenayre.com...
> Hi Loiy,
> something like:
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> <prompt>
> // JAVA Scriptlet
> </prompt>
> </block>
> </form>
> </vxml>
>> -- Mike Greenawalt
Re: java in voicexml [message #574798 is a reply to message #14127] Wed, 31 May 2006 20:21 Go to previous messageGo to next message
-- Mike Greenawalt
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> </form>
> </vxml>
> loiy
Re: java in voicexml [message #574938 is a reply to message #14163] Tue, 20 June 2006 16:46 Go to previous messageGo to next message
Hi Loiy,
something like:
<form id="say_hi">
<block>
</block>
</form>
<block>
<prompt>
// JAVA Scriptlet
</prompt>
</block>
</form>
</vxml>
> -- Mike Greenawalt
Re: java in voicexml [message #576111 is a reply to message #14216] Wed, 07 February 2007 09:36 Go to previous messageGo to next message
Hi Paul,
using VTP-GUI?
> Hi Loiy,
> something like:
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> <prompt>
> // JAVA Scriptlet
> </prompt>
> </block>
> </form>
> </vxml>
>> -- Mike Greenawalt
Re: java in voicexml [message #634515 is a reply to message #574798] Fri, 22 October 2010 00:15 Go to previous message
Mike Greenawalt wrote on Wed, 31 May 2006 20:21
-- Mike Greenawalt
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> </form>
> </vxml>
Previous Topic:Cannot run the "Getting Started" example
Next Topic:java
Current Time: Sat Jul 12 00:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.05351 seconds
