Home » Language IDEs » Java Development Tools (JDT) » Viewing multiple files
Viewing multiple files [message #150657] Thu, 25 March 2004 13:32 Go to next message
Originally posted by: jar.ornl.gov
How do I use Eclipse 3 to view multiple files in the editor at the same
time so that I can compare them?
Re: Viewing multiple files [message #150673 is a reply to message #150657] Thu, 25 March 2004 14:33 Go to previous messageGo to next message
Open 2 editors.
Drag one of them down to the bottom of the editor area until the drop icon
becomes a down arrow.
Drop
You can also select two files in the PackageExplorer, ContextMenu>Compare
With>Each Other
HTH
Darins
"Jim Rome" <jar@ornl.gov> wrote in message news:c3v8kc$hf6$1@eclipse.org...
Re: Viewing multiple files [message #150763 is a reply to message #150673] Fri, 26 March 2004 11:07 Go to previous messageGo to next message
I must be missing something, but how do you open two editors?
It would also be really nice if I could view more than 2 files at once in
the editor pane. And also several parts of the same file. Is there a
window split command?
Jim
Darin Swanson wrote:
> Open 2 editors.
> Drop
> With>Each Other
Re: Viewing multiple files [message #150769 is a reply to message #150673] Fri, 26 March 2004 11:11 Go to previous messageGo to next message
I guess opening an editor = opening a file. So I have several open. If I
drag the top bar too the bottom or the right, I do get the arrow, and a
black line for a split appears, but when I release the mouse, nothing
changes.
Jim
> Open 2 editors.
> Drop
> With>Each Other
> HTH
> Darins
Re: Viewing multiple files [message #150774 is a reply to message #150673] Fri, 26 March 2004 11:17 Go to previous message
I figured it out. The "tab" is not really a tab. It is the little icon
that looks like a square root sign. Dragging the icon works. Dragging
other spots on the bar appears to work, but does not.
Previous Topic:AbstractUIPlugin cannot be resolved or is not a valid superclass
Next Topic:Short Question about Project Plan
Current Time: Thu Nov 06 17:01:12 EST 2025
Powered by FUDForum. Page generated in 0.03989 seconds
