Home » Eclipse Projects » GEF » WSDL VIEWER
WSDL VIEWER [message #150457] Fri, 10 September 2004 10:42 Go to next message
Originally posted by: DSEHVAR.YAHOO.COM
hi,
i have downloaded and the zip version of WSDL viewer from
http://www.improve-technologies.com/alpha/wsdl-viewer/#using . Although it
seems to be installed Eclipse does not associate this editor to my wsdl
files. Have you ever used this tool? Any help appreciated
Re: WSDL VIEWER [message #150575 is a reply to message #150457] Sat, 11 September 2004 14:20 Go to previous message
Do you have the correct version of Eclipse (2.1.3) and GEF? Make sure you
only have one version of the GEF plug-in (2.1.3). The plugin.xml should be
registering the editor with WSDL files. Is the WSDL editor option even
available? Is it listed under "Open with" for WSDL files? How do you know
the plug-ins are installed properly? Do they show up as enabled in the
about dialog?
Try the contacts at improve-technologies.com for more help.
"EBRU KILIC" <DSEHVAR@YAHOO.COM> wrote in message
news:chseh9$sq1$1@eclipse.org...
> hi,
Previous Topic:Where I can find org.eclipse.ui.part?
Next Topic:adjusting a layout
Current Time: Fri Nov 21 04:57:11 EST 2025
Powered by FUDForum. Page generated in 0.03658 seconds
