Home » Language IDEs » C / C++ IDE (CDT) » debugger disabling breakpoint does not work
debugger disabling breakpoint does not work [message #150290] Fri, 29 July 2005 05:12 Go to next message
Originally posted by: frank.morauf.salzbrenner.com
Eclipse Version: 3.1.0 Build id: I20050627-1435
org.eclipse.cdt-3.0.0-I200507251030-win32.x86.zip
Disabling of breakpoints does not work. The debugger always stops.
If you look in the gdb-console and type "info breakpoints" you can see
that all bps are enabled. Disabling a bp in the gdb-console works but is
not recognized by cdt-ui.
Re: debugger disabling breakpoint does not work [message #150326 is a reply to message #150290] Fri, 29 July 2005 11:35 Go to previous message
Originally posted by: mikhailk.qnx.com
This is fixed. Try the latest build.
"Frank Morauf" <frank.morauf@salzbrenner.com> wrote in message
news:861a1b40cec0b6ddefa69a74f5e57537$1@www.eclipse.org...
> Disabling of breakpoints does not work. The debugger always stops. If you
> look in the gdb-console and type "info breakpoints" you can see that all
> bps are enabled. Disabling a bp in the gdb-console works but is not
Previous Topic:Content Assist/Indexing not working when linking project with TAO
Next Topic:Indexer and Builder Lockups
Current Time: Fri Nov 07 22:17:35 EST 2025
Powered by FUDForum. Page generated in 0.03989 seconds
