Home » Archived » DSDP - Mobile Tools for Java (MTJ) » FW: Run and Debug j2me as "installed JREs"
| FW: Run and Debug j2me as "installed JREs" [message #14048] |
Fri, 10 March 2006 10:54  |
Forward from eclipse.dsdp to eclipse.dsdp.mtj newgroup
Martin Oberhuber - WindRiver, Austria
+43(662)457915-85
Keanu, Paik wrote:
> I'd like to use IBM j9 VM, j2me CDC VM I have, as "Installed JREs" when
> I develop eclipse application.
> However the panel, "windows > preferences > java > installedJREs",
> does not fit well with IBM j9 (CDC / FP 1.0).
> I tried with "add" butten, only to fail.
> I tried with "search" button, finding some directories.
> However the directory found by "search" function is wrong directories.
> steps
> 1) hit "search button" in the panel "Installed JREs"
> 2) select directory "C:\java\wsdd571\wsdd5.0\ive-2.2" which IBM j9 VMs
> are under the directory.
> 3) Brings some awkward directories as "found".
> I tried same funtions with Sun J2SE VM, and it works well.
> How can I run and debug IBM j9, or other j2me VM available, explicitly
> with the current eclipe 3.x?
| Re: FW: Run and Debug j2me as "installed JREs" [message #14066 is a reply to message #14048] |
Fri, 10 March 2006 14:30   |
MTJ currently does not have any code to help you.
You are looking for org.eclipse.jdt.launching.j9 in the eclipse project.
You can see the code at
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jdt.lau nching.j9/
and can follow the eclipse instructions to download and build it. I
don't know where it is provided in binary format.
Once you have this fragment in your workbench, you will be able to add
J9 VMs into eclipse.
For more information you can look at
news://news.software.ibm.com/ibm.software.websphere.studio.d evice-developer
kevin
> +43(662)457915-85
>> when I develop eclipse application.
>> steps
| Re: FW: Run and Debug j2me as "installed JREs" [message #14083 is a reply to message #14066] |
Fri, 10 March 2006 18:55   |
Originally posted by: seterajunk.charter.net
Until MTJ has the function you need, you may also want to consider
EclipseME (http://eclipseme.org).
Craig
EclipseME Developer and MTJ Architect
> kevin
>> +43(662)457915-85
>>> steps
>>> VMs are under the directory.
>>> explicitly with the current eclipe 3.x?
| Re: FW: Run and Debug j2me as "installed JREs" [message #564173 is a reply to message #14048] |
kevin
> +43(662)457915-85
>> steps
| Re: FW: Run and Debug j2me as "installed JREs" [message #564198 is a reply to message #14066] |
Craig
> kevin
>> +43(662)457915-85
>>> steps
Current Time: Sat Nov 22 23:38:16 EST 2025
Powered by FUDForum. Page generated in 0.03976 seconds
