Home » Language IDEs » C / C++ IDE (CDT) » Error Parser Grammar
Error Parser Grammar [message #150163] Wed, 27 July 2005 16:05 Go to next message
I'd like to understand the error parser grammars. Can someone give me a
pointer to either documentation, or a specific area in the source tree?
Re: Error Parser Grammar [message #150185 is a reply to message #150163] Wed, 27 July 2005 17:34 Go to previous messageGo to next message
nm - I found it.
Re: Error Parser Grammar [message #150199 is a reply to message #150185] Thu, 28 July 2005 08:35 Go to previous messageGo to next message
Could you be so kind to point the place?
Currently I'm workin gon problem with using Ant CPPTask pluging and CDT
- probably it will help me.
>> a pointer to either documentation, or a specific area in the source tree?
> nm - I found it.
Re: Error Parser Grammar [message #150204 is a reply to message #150199] Thu, 28 July 2005 11:36 Go to previous messageGo to next message
Certainly.
I looked at the Eclipse CVS repository. The following URL will take you
to the parent directory of the error parsers that ship with Eclipse:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.cdt-cor e/org.eclipse.cdt.core/src/org/eclipse/cdt/internal/errorpar sers/?cvsroot=Tools_Project#dirlist
Re: Error Parser Grammar [message #150267 is a reply to message #150204] Fri, 29 July 2005 00:57 Go to previous message
Thank you a lot.
So, the problem to understand C++ bugs from Ant (then it is used with
CppTasks) is only to migrate this parsers to Ant or to tell CDT use this
parsers not only in Make-build, but in Ant-Build too...
Will work.
>> CDT - probably it will help me.
> Certainly.
Previous Topic:CDT Debugger : Can't pass command line args
Next Topic:PC-lint?
Current Time: Sun Nov 09 09:25:41 EST 2025
Powered by FUDForum. Page generated in 0.04550 seconds
