Home » Language IDEs » ServerTools (WTP) » How to get the HTML content type to expose my schem extensions?
How to get the HTML content type to expose my schem extensions? [message #150050] Wed, 30 November 2005 16:17 Go to next message
Greetings,
I'm attempting to define an alternate XML Schema for XHTML, using W3C's
xhtml11.xsd + some modifications (namely adding XForms elements as valid
child nodes of XHTML nodes).
So I've updated my simple.xhtml file as such (adding xsi:schemaLocation):
<?xml version="1.0" encoding="ASCII"?>
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:xforms="http://www.w3.org/2002/xforms"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.w3.org/1999/xhtml xhtml+xforms.xsd">
<head>
So it has a direct link to my modified schema. The content assist and
validator don't recognize my changes. Though, if I rename my file to
simple.xml, then it does work as expected (recognizing the child
elements from XForms).
So my question is, is there a way I can extend the HTML content model to
recognize alternate/extended XHTML syntax?
Thanks in advance,
Steve Speicher
Re: How to get the HTML content type to expose my schem extensions? [message #151161 is a reply to message #150050] Thu, 08 December 2005 13:28 Go to previous message
To follow up on this, I've create enhancement request to track this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=119084
In short, there are some limitations in attempting to do this.
- Steve
Steve Speicher wrote:
> Greetings,
> W3C's xhtml11.xsd + some modifications (namely adding XForms elements
> as valid child nodes of XHTML nodes).
> <head>
> to recognize alternate/extended XHTML syntax?
> Thanks in advance,
> Steve Speicher
Previous Topic:Classes of dependent projects
Next Topic:How to add new context parameter to WebApp
Current Time: Sun Nov 23 07:39:26 EST 2025
Powered by FUDForum. Page generated in 0.02658 seconds
