Home » Eclipse Projects » Orbit »  JAX-WS 2.0
 JAX-WS 2.0 [message #14004] Mon, 04 August 2008 16:06 Go to next message
The ORMF project requires JAX-WS 2.0. I would be happy to bundle this
for Orbit if it is wanted. Can I get my CQ and an Orbit CQ approved in
parallel or should I get usage of the libraries approved before
starting a process with Orbit.
All the best,
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme and the
|) ::: (| Open Requirements Management Framework
====w=w==== [http://www.eclipse.org/ormf]
Re: JAX-WS 2.0 [message #14012 is a reply to message #14004] Mon, 04 August 2008 16:27 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Joel Rosi-Schwartz wrote:
> parallel or should I get usage of the libraries approved before starting
You can do both at the same time. I'd file the CQ for JAX-WS 2.0 against
ORMF first, than a CQ in Orbit for reuse of the previous CQ.
~ Chris
Re: JAX-WS 2.0 [message #14028 is a reply to message #14012] Tue, 05 August 2008 11:43 Go to previous messageGo to next message
> against ORMF first, than a CQ in Orbit for reuse of the previous CQ.
> Cheers,
> ~ Chris
Thanks Chris, will do. I am waiting on the answer to a question I asked
the emo-ip team, but perhaps you know the answer. Here is the question
as I posed it:
Before I start filling out a CQ I would like your advice on how to
structure it. JAX-WS is a standard Java 5 EE component that is
developed as a part of Glassfish here. It is distributed as a
single executable jar file that installs as a hierarchy which contains
16 jar files. The source for JAX-WS is also distributed as a
single executable jar file that installs as a hierarchy, but the source
for all target jars are in a unified tree. Is it possible to have the
entire library approved in one go or do I have to fill in 16 CQ? If I
need to do 16 CQ, should I create a 17th that contains the source and
point all of the other to it or attach a copy of the source to each?
Can you advise on this or should I wait for an answer from them?
Joel
Joel Rosi-Schwartz
|) ::: (| The Open Requirements Management Too
====w=w==== [https://useme.dev.java.net]
Re: JAX-WS 2.0 [message #14043 is a reply to message #14028] Tue, 05 August 2008 12:05 Go to previous messageGo to next message
I'd wait on what the IP team has to say.
It depends what those 16 folders are... if it's just all source
representative of JAX-WS than 1 CQ should be enough. However, if those
16 folders represent JAX-WS dependencies than that could be an issue and
require separate CQs.
Good luck!
~ Chris
Re: JAX-WS 2.0 [message #14057 is a reply to message #14043] Tue, 05 August 2008 16:32 Go to previous messageGo to next message
> and require separate CQs.
> Good luck!
> Cheers,
> ~ Chris
Chris,
I am having an on going conversation with Sharon Corbett on this. I am
going to add you to the CC list as I think you might want to express
your opinion from the Orbit perspective.
/joel
Joel Rosi-Schwartz
Re: JAX-WS 2.0 [message #14074 is a reply to message #14012] Thu, 07 August 2008 11:05 Go to previous message
> Cheers,
> ~ Chris
I have filed the CQs for JAX-WS 2.0 runtime (jaxws-rt.jar) and for the
nine 3rd party libraries from JAX-WS 2.0 that ORMF requires. A couple
of these are already from Orbit as I have indicated below. I am willing
to bundle the balance for Orbit or the subset that you consider of
value. I also want to create a single bundle that acts as a JAX-WS
client component which contains all of these, would Orbit be interested
in carrying the combined bundle as well? I am thinking about using "
Option 1 : Dominant package name" for all of this, do you agree with
that?
You suggested that I file the ORMF CQs first then the Orbit as PB. Does
this mean that After the bundles are in Orbit, I have to file new CQs
to us the ones from Orbit or is the packaging just a technicality the
EMO IP team is not concerned with.
javax.activation_1.1.0.v200806101325.jar [CQ 2565 - using Orbit]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2565)
jaxb-api.jar [CQ 2560] (https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2560)
jaxb-impl.jar [CQ 2562]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id= 2562)
jaxws-api.jar [CQ 2566 - using Orbit]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2566)
jaxws-rt.jar {[CQ 2571] (https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2571)
jsr173_api.jar [CQ 2563]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2563)
resolver.jar - [CQ 2569]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2569) waiting for
reply from JAX-WS team
saaj-api.jar [CQ 2567] (https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2567)
saaj-impl.jar - [CQ 2570]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2570)
sjsxp.jar - [CQ 2572]
(https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2572) waiting for
Joel
Re: JAX-WS 2.0 [message #564044 is a reply to message #14004] Mon, 04 August 2008 16:27 Go to previous message
~ Chris
Re: JAX-WS 2.0 [message #564064 is a reply to message #14012] Tue, 05 August 2008 11:43 Go to previous message
> Cheers,
> ~ Chris
as I posed it:
Joel
Joel Rosi-Schwartz
Re: JAX-WS 2.0 [message #564094 is a reply to message #14028] Tue, 05 August 2008 12:05 Go to previous message
Good luck!
~ Chris
Re: JAX-WS 2.0 [message #564110 is a reply to message #14043] Tue, 05 August 2008 16:32 Go to previous message
> Good luck!
> Cheers,
> ~ Chris
Chris,
/joel
Joel Rosi-Schwartz
Re: JAX-WS 2.0 [message #564128 is a reply to message #14012] Thu, 07 August 2008 11:05 Go to previous message
> Cheers,
> ~ Chris
that?
Joel
Previous Topic: JAX-WS 2.0
Next Topic:xalan / Xerces Bundles Export Version Numbers
Current Time: Wed Oct 15 07:10:32 EDT 2025
Powered by FUDForum. Page generated in 0.05448 seconds
