Error starting eclipse [message #149533] |
Sun, 23 April 2006 19:21  |
Originally posted by: carlo.casorzo.gmail.com
I unzip eclipse and execute eclipse.exe, and it starts loading, but i keep
getting this error:
JVM Terminated. Exit code=-10737
C:\Windows\system32\javaw.exe
-Xms40m
-Xmx56m
-jar D:\eclipse\startup.jar
-os win32
-ws win32
-arch x86
-launcher D:\eclipse\eclipse.exe
-name Eclipse
-showsplash 600
-exitdata 1e0_64
-vm C:\WINDOWS\system32\javaw.exe
-vmargs
-Xms40m
-Xmx256m
This isn't a log file, is a dialog window with this text.
If somebody knows how to fix it, please tell me how!! I'm new to eclipse
and I really need to work with it now.
THANKS!!
Re: Error starting eclipse [message #149538 is a reply to message #149533] |
Sun, 23 April 2006 19:39  |
See http://wiki.eclipse.org/index.php/FAQ_How_do_I_run_Eclipse%3 F
Especially:
"You should always use -vm so you can be sure of what VM you are using.
Installers for other applications sometimes modify the JAVA_HOME variable,
thus changing the VM used to launch Eclipse without your knowing about it.
Use -vm and point to an install of a 1.4.2 or later JDK/JRE install
HTH
Darins
"Carlo Casorzo G." <carlo.casorzo@gmail.com> wrote in message
news:4276bc65688fdebc128b8e2d1a052df7$1@www.eclipse.org...
>getting this error:
> -Xms40m
> -Xmx56m
> -os win32
> -ws win32
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 1e0_64
> -vmargs
> -Xms40m
> -Xmx256m
> THANKS!!
FUDForum. Page generated in 0.07882 seconds
