Home » Modeling » GMF (Graphical Modeling Framework) » Make a node fill another nodes compartment
Make a node fill another nodes compartment [message #149461] Fri, 07 September 2007 08:03 Go to next message
Hi!
I have a Node A with 2 compartments. In each compartment I can create one
child node (Node B). Everything works fine, but I want the node that I
create in Node A:s compartment to fill that compartment completely.
Is this possible?
This is what I have now:
________________
| Node A |
| ___________ |
| | Node B | |
| |___________| |
|________________|
|________________|
And this is what I want:
________________
| Node A |
| Node B |
|________________|
|________________|
Johan
Re: Make a node fill another nodes compartment [message #149464 is a reply to message #149461] Fri, 07 September 2007 08:52 Go to previous messageGo to next message
Johan,
you should use a StackLayout in your compartment figure
Johan Linander a écrit :
> Hi!
> one child node (Node B). Everything works fine, but I want the node that
> I create in Node A:s compartment to fill that compartment completely. Is
> this possible?
> ________________
> | Node A |
> | ___________ |
> | | Node B | |
> | |___________| |
> |________________|
> |________________|
> ________________
> | Node A |
> | Node B |
> |________________|
> |________________|
> Regards
> Johan
Re: Make a node fill another nodes compartment [message #149929 is a reply to message #149464] Tue, 11 September 2007 05:15 Go to previous messageGo to next message
I have now tried using a stack layout in the compartment figure, but it
didn't work for me. The nodes that I create in the compartment does not
fill the entire compartment..
Any other suggestions?
Jacques LESCOT wrote:
> Johan,
Re: Make a node fill another nodes compartment [message #149944 is a reply to message #149929] Tue, 11 September 2007 05:22 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
try using stack layout for the figure containing the compartment.
>> Johan,
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFG5l5cIYVWjMSpDwwRAv/7AKDBrQuntNh3vHCEUz3JBOpR4bpU2QCf Rmqq
3Ws/MXHQdvFx4xUKkk1iOlM=
=DG5G
-----END PGP SIGNATURE-----
Re: Make a node fill another nodes compartment [message #151778 is a reply to message #149944] Thu, 20 September 2007 05:11 Go to previous message
Can't get this to work.. :(
johan
> Hash: SHA1
Previous Topic:Re-generation of gmfgen when gmfmap has changed
Next Topic:Not displaying node attributes
Current Time: Sun Aug 31 15:31:18 EDT 2025
Powered by FUDForum. Page generated in 0.02759 seconds
